回复: 17
三轴飛行器視頻
发表于 2008-8-27 14:44:57 | 显示全部楼层 |阅读模式
http://www.draganfly.com/uav-helicopter/draganfHimem-x6/gallery/videos/
雖然使用三軸,但是卻使用了6個電機的
发表于 2008-8-27 15:41:34 | 显示全部楼层
强!!
发表于 2008-8-27 16:02:46 | 显示全部楼层
I like it.
发表于 2008-8-28 15:22:32 | 显示全部楼层
他们终于推出重量级产品了,这可是比MICRODRONE老牌的公司,鼻祖级的。三轴比四旋翼漂亮!
发表于 2008-8-28 16:07:53 | 显示全部楼层
(原文件名:DF-X6_1.jpg)
(原文件名:DF-X6_12.jpg)
(原文件名:DF-X6_13.jpg)
(原文件名:DF-X6_14.jpg)
(原文件名:DF-X6_15.jpg)
(原文件名:DF-X6_17.jpg)
(原文件名:DF-X6_18.jpg)
(原文件名:DF-X6_19.jpg)
(原文件名:DF-X6_2.jpg)
(原文件名:DF-X6_21.jpg)
(原文件名:DF-X6_23.jpg)
(原文件名:DF-X6_3.jpg)
(原文件名:DF-X6_6.jpg)
(原文件名:DF-X6_7.jpg)
(原文件名:DF-X6_8.jpg)
发表于 2008-8-28 16:11:02 | 显示全部楼层
2600mAh锂聚电池,可以飞25分钟
发表于 2008-8-28 16:27:38 | 显示全部楼层
有人知道价钱吗?
发表于 2008-8-28 16:38:16 | 显示全部楼层
看那块线路板与全碳纤结构,估计就得N万
发表于 2008-8-28 17:04:08 | 显示全部楼层
贵在哪里?
发表于 2008-8-28 18:04:21 | 显示全部楼层
你把这些都做在一起,你说能不贵吗?
11 Onboard Sensors
3 Solid State MEMS (Micro-Electro-Mechanical Systems) Gyros
3 Solid State MEMS (Micro-Electro-Mechanical Systems) Accelerometers
3 Magnetometers (Magnetoresistive Sensors)
1 Barometric Pressure Sensor
1GPS
GPS Used For: Position Hold, Location & Velocity Data
Maximum Satellites Tracked Simultaneously: 16
Position Update Rate: 4 Hz
GPS Antenna: Ceramic Patch
2.4GHz Data Link
Link Type: Helicopter to Ground & Ground to Helicopter (Two-Way)
Helicopter Antenna: Wired Whip Antenna
Controller Antenna: Omni-Directional
Transmission Power (North America): 50mW (+17dBm)
Transmission Power (International): 10mW (+10dBm)
RF Data Rate: 250kbps
Receiver sensitivity: -102dBm
Transmission Technique: DSSS (Direct Sequence Spread Spectrum)
Frequency band: 2.4000 - 2.4835 GHz
Certifications: CE, FCC, IC, ETSI
Data Link Channel Selection: Automatic (13 Channels)
5.8GHz Video Link
Link Type: Helicopter to Ground (One-Way)
Transmitter Antenna: Omni-Directional
Receiver Antennas: Omni-Directional & Flat Patch
Transmission Power: 12dBm
Transmitter Power Consumption: 500mW
NTSC and PAL Compatible
7 Selectable Channels: 5740MHz, 5760MHz, 5780MHz, 5800MHz, 5820MHz, 5840MHz, 5860MHz
发表于 2008-8-28 19:28:13 | 显示全部楼层
发表于 2008-8-28 23:44:58 | 显示全部楼层
【9楼】 feng_matrix
我的mikrokopter也不差
3 Solid State MEMS (Micro-Electro-Mechanical Systems) Gyros  (正在联系购买, 具体型号暂时卖一下关子, 40美金一个)
3 Solid State MEMS (Micro-Electro-Mechanical Systems) Accelerometers  (现在用的不知道算不算mems的)
3 Magnetometers (Magnetoresistive Sensors)  (朋友正在搞板)
1 Barometric Pressure Sensor  (已经有啦)
1GPS (今天刚刚收到, LEA-5h, 也是可以锁定16颗卫星,也是4HZ)
2.4GHz Data Link  (Futaba 10CHP 2.4G遥控, 这个星期6去购买)
5.8GHz Video Link  (我是2.4G的)
发表于 2008-8-29 10:19:12 | 显示全部楼层
to : 【11楼】 RickyZhou
哈哈,把这些设备全加上,先不包括碳纤整体机架、研发费用、管理成本,你算算要多少费用?
 楼主| 发表于 2008-8-29 10:39:24 | 显示全部楼层
【12楼】 feng_matrix
找到的圖片真美!
发表于 2008-8-30 10:16:45 | 显示全部楼层
赞!羡!
发表于 2009-4-1 14:46:31 | 显示全部楼层
这个看着多舒服!
发表于 2009-4-1 15:56:48 | 显示全部楼层
看上去,有点象异型和铁血战士。。。。。。。
DraganfHimem X6
(New Helicopter)
$14,999.95
价钱在13~15万RMB之间
(原文件名:price.JPG)
发表于 2009-4-1 16:02:47 | 显示全部楼层
不知这个电机的内部结构,不过世界80%的小电机,都是在中国生产和组装的
GMT+8, 2024-7-24 16:14
