#include <avr\io.h>
#include <util\delay.h>
#include <avr\eeprom.h>
#include <avr\pgmspace.h>
#include <avr\interrupt.h>
#include "1504.h"
#include "lcd12864.h"
#define LE 4
#define DATA 3
#define CLK 2
#define CLR_LE PORTC&=~(1<<LE)
#define SET_LE PORTC|=(1<<LE)
#define CLR_DATA PORTC&=~(1<<DATA)
#define SET_DATA PORTC|=(1<<DATA)
#define CLR_CLK PORTC&=~(1<<CLK)
#define SET_CLK PORTC|=(1<<CLK)
volatile unsigned char AutoSearchStop=0;
extern volatile unsigned int Timer0InterTimes,Freq[],EEAddr,FreqH[],FreqL;
extern volatile unsigned char Station,Channel[4],Segment,Select[4];
void ShortDelay(void)
_delay_us(2);
void PLL_Reference(unsigned int R,unsigned char SW)
char i;
CLR_CLK;
CLR_LE;
R<<=1;
R|=1; //C为1移入16位数据,C为0,移入18位数据
if(SW)
R|=0x8000;
for(i=0;i<16;i++)
if(R&0x8000)
SET_DATA;
CLR_DATA;
ShortDelay();
SET_CLK;
ShortDelay();
CLR_CLK;
ShortDelay();
R<<=1;
SET_LE;
ShortDelay();
CLR_LE;
ShortDelay();
void PLL_Programe(unsigned char A,unsigned int N)
unsigned char i,temp_A=A;
unsigned int temp_N=N;
CLR_CLK;
CLR_LE;
temp_A<<=1;
temp_N<<=5;//11位数据变为16位数据
for(i=0;i<11;i++)//传送N
if(temp_N&0x8000)
SET_DATA;
CLR_DATA;
ShortDelay();
SET_CLK;
ShortDelay();
CLR_CLK;
ShortDelay();
temp_N<<=1;
for(i=0;i<8;i++) //传送A
if(temp_A&0x80)
SET_DATA;
CLR_DATA;
ShortDelay();
SET_CLK;
ShortDelay();
temp_A<<=1;
CLR_CLK;
ShortDelay();
ShortDelay();
SET_LE;
ShortDelay();
CLR_LE;
ShortDelay();
void MSM1504_Init(void)
DDRC|=(1<<LE)|(1<<DATA)|(1<<CLK);
void SetFreq(unsigned int F)
unsigned int N,A;
if(Segment==1)
F+=465;
F+=1070;
N=F/32;
A=F%32;
PLL_Programe(A,N);
