发表于 2009-4-23 20:48:59
还是开始的点灯程序,最最简单的,全汇编的,不需要别的设置,直接拉过来用,编译通过,Proteus仿真,没问题,哈哈,以为好了呢,换C程序的,带个汇编的启动文件,问题来了,开始是error: L6236E: No section matches selector - no section to be FIRST/LAST. 什么原因呢,呵呵,原来是S文件里面的AREA init,CODE,READONLY ;出问题了,由于选了分散加载文件,系统默认的模块是RESET,而这里是init,换掉,问题又来了 Error: L6238E: startup.o(RESET) contains invalid call from '~PRES8' function to 'REQ8' function main. 这个问题原来是(百度了一篇文章)
This RVDS/RVCT linker error is given where a stack alignment conflict is detected in object code. The "ABI for the ARM Architecture" demands that code maintains 8-byte stack alignment at its interfaces. This allows efficient use of
Symbols like '~PRES8' and 'REQ8' are "" of the objects.
This link error typically occurs in two cases:
where assembler code (that does not preserve 8-byte stack alignment) calls compiled C/C++ code (that requires 8-byte stack alignment), and
when attempting to link legacy SDT/ADS objects with RVCT 2.x objects. Legacy SDT/ADS objects that do not have these attributes are treated as '~PRES8', even if they do actually happen to preserve 8-byte alignment.
For example:
This means that there is a function in the object
A similar warning that may be encountered, where the address of an external symbol is being referred to, is:
Solutions
There are two possible approaches to dealing with this issue:
1) If you have access to all your source code and are allowed to rebuild it
In this case you should rebuild all your objects/libraries using the latest version of the compilation tools. Note that if you have any assembler files, you will need to:
i) check that all instructions preserve 8-byte stack alignment, and if necessary, correct them.
e.g. change:
to:
and:
ii) add the
e.g. change:
to:
AREA Init, CODE, READONLY (the
2) If you cannot rebuild all of your source code
If you have any legacy objects/libraries that cannot be rebuilt, either because you do not have the source code, or because the old objects must not be rebuilt (e.g. for qualification/certification reasons), then you must inspect the legacy objects to check whether they preserve 8-byte alignment or not. Use "" to disassemble the object code. C/C++ code compiled with ADS 1.1 or later will normally preserve 8-byte alignment, but assembled code will not.
If your objects do indeed preserve 8-byte alignment, then the linker error If you are linking with legacy objects/libraries then you should also read the information on the option "" in the FAQ entry "Are legacy ADS objects/libraries compatible with RVCT 2.0 ?".
改了这个 又出现新问题了
Error: L6915E: Library reports error: scatter-load file declares no heap or stack regions and __user_initial_stackheap is not defined。由于我的S文件也是用的最简单的,堆栈指针就( LDR SP,=0x40003F00 ; 设置堆栈指针)这样设置了,看来这样行不通了,取消分散加载选项
(原文件名:910008599706778538.jpg)
也就是Use Memory Layout from Target Dialog这个前面的勾去掉,删除Scatter File选项里的文件,就成下面的图了
(原文件名:886646176639981858.jpg)
看下面的Linker control string ,ro-base:0x00000000,entry 0x00000000 rw-base 0x40003000,就是我想要的嘛,编译,通过,哈哈,以为OK了,proteus仿真,问题来了,完全没反应啊,找原因,呵呵,还是和上次ADS的问题一样,需要在Misc controls里面写上 --first startup.o(init) ,只是设置方法不同而已,后面的startup就是S启动文件的名称啦,init是程序开始入口的模块名称,根据自己的换就是了,再编译,通过,仿真,哈哈,没问题啦 |
