#include <LPC214X.H>
#include "delay.h"
#define USE_FAST_IO
#define GPIO0M 0x00000001
#define GPIO1M 0x00000002
#define SetPortBit(port,bit) port=port|(1<<bit)
#define ClrPortBit(port,bit) port=port&(~(1<<bit))
#define GetPortBit(port,bit) port&(1<<bit)
#define NACK 0
#define SACK 1
#define IO_GND (unsigned int)(1<<19) //0x00080000
#define IO_SDA (unsigned int)(1<<21) //0x00200000
#define IO_SCL (unsigned int)(1<<23) //0x00800000
unsigned char f_I2C_Error=0;
//unsigned char GetBit(unsigned char DDRport,unsigned char bit)
#define LSB(a) ((unsigned char)a)
#define MSB(a) ((unsigned char)(a>>8))
void IicBusDelay( void )
//delay_us(5);
void ClrSCL(void)
//P1.19 P1.21 P1.23
#ifdef USE_FAST_IO
FIO1DIR=FIO1DIR|(IO_SCL)|(IO_SDA)|(IO_GND);
FIO1MASK = ~(IO_SCL);
FIO1PIN = 0x00000000;
#else
IO1DIR=IO1DIR|(IO_SCL)|(IO_SDA)|(IO_GND);
IO1CLR = IO_SCL;
IicBusDelay();
void ClrSDA(void)
//P1.19 P1.21 P1.23
#ifdef USE_FAST_IO
FIO1MASK = ~(IO_SDA);
#else
IO1CLR = IO_SDA;
IicBusDelay();
unsigned char GetSDA(void)
unsigned int val;
//P1.19 P1.21 P1.23
#ifdef USE_FAST_IO
FIO1DIR=FIO1DIR&(~(IO_SDA));
FIO1DIR=FIO1DIR|(IO_SCL)|(IO_GND);
delay_us(1);
val=FIO1PIN;
#else
IO1DIR=IO1DIR&(~(IO_SDA));
IO1DIR=IO1DIR|(IO_SCL)|(IO_GND);
delay_us(1);
val=IO1PIN;
val=val & IO_SDA;
if(val)
return 1;
return 0;
unsigned char GetSCL(void)
unsigned int val;
//P1.19 P1.21 P1.23
#ifdef USE_FAST_IO
FIO1DIR=FIO1DIR&(~(IO_SCL));
FIO1DIR=FIO1DIR|(IO_SDA)|(IO_GND);
delay_us(1);
val=FIO1PIN;
#else
IO1DIR=IO1DIR&(~(IO_SCL));
IO1DIR=IO1DIR|(IO_SDA)|(IO_GND);
delay_us(1);
val=IO1PIN;
val=val & IO_SCL;
if(val)
return 1;
return 0;
void SetSCL(void)
unsigned char chr1;
#ifdef USE_FAST_IO
FIO1PIN = IO_SCL;
#else
IO1SET = IO_SCL;
if( GetSCL() == 1 ) return ;
for(chr1=0; chr1<255; chr1++) // 为避免数据传送时受IIC总线上大电容(100-1000P)的影响,以及适应某些反应速度慢的IC在做出反应前拉低SCL的做法
if( GetSCL() == 1 ) break ;
void SetSDA(void)
unsigned char chr1;
#ifdef USE_FAST_IO
FIO1PIN = IO_SDA;
#else
IO1SET = IO_SDA;
if( GetSDA() == 1 ) return ;
if( GetSDA() == 1 ) break ;
void ACK(unsigned char ack)
if(!ack) //非应答
SetSDA();
else //应答
ClrSDA();
IicBusDelay();
SetSCL();
IicBusDelay();
ClrSCL();
IicBusDelay();
void I2CInit(void)
f_I2C_Error=0;
PINSEL2=PINSEL2&0xfffffff7;//P1.25 -16 用作GPIO 管脚
PINSEL2=PINSEL2|0x00000004;//P1.31 - 26 用作一个调试端口
//P1.19 P1.21 P1.23
#ifdef USE_FAST_IO
SCS |= GPIO1M; /* set GPIOx to use Fast I/O */
FIO1MASK = ~(IO_GND);
#else
IO1CLR = IO_GND;
void IicStart(void)
f_I2C_Error=0;
IicBusDelay();
SetSDA();
IicBusDelay();
SetSCL();
IicBusDelay();
if( GetSDA()==0)
f_I2C_Error = 1 ;
return ;
if( GetSCL()==0 )
f_I2C_Error = 1 ;
return ;
ClrSDA();
IicBusDelay();
ClrSCL();
IicBusDelay();
void IicStop( void )
IicBusDelay();
ClrSDA();
IicBusDelay();
SetSCL();
IicBusDelay();
SetSDA();
IicBusDelay();
void IicSendByte(unsigned char chr)
unsigned char i;
for(i=0;i<8;i++)
if(chr&0x80)
SetSDA();
ClrSDA();
SetSCL();
IicBusDelay();
ClrSCL();
chr<<=1;
IicBusDelay();
IicBusDelay();
SetSDA();
IicBusDelay();
SetSCL();
IicBusDelay();
if(GetSDA())
f_I2C_Error=1; //失败
f_I2C_Error=0;
ClrSCL();
IicBusDelay();
unsigned char IicReceiveByte(unsigned char ack)
unsigned char i,rval;
rval=0;
SetSDA();
for(i=0;i<8;i++)
IicBusDelay();
ClrSCL();
IicBusDelay();
SetSCL();
IicBusDelay();
rval<<=1;
if(GetSDA())
rval++;
ClrSCL();
IicBusDelay();
ACK(ack);
return(rval);
