发表于 2008-7-29 08:59:00
用过 calloc 这个函数
//矩阵倒置,A为倒置前矩阵,AInverse为结果矩阵;
//矩阵均为n行,n列
static int matrix_inversion(float xdata * A, int n, float xdata * AInverse)
// Matrix Inversion Routine
// A = input matrix (n x n)
// n = dimension of A
// AInverse = inverted matrix (n x n)
// This function inverts a matrix based on the Gauss Jordan method.
// The function returns 1 on success, 0 on failure.
int xdata i, j, iPass, imx, icol, irow;
float xdata det, temp, pivot, factor;
float * ac = (float *)calloc(n*n, sizeof(float));
det = 1;
for (i = 0; i < n; i++)
for (j = 0; j < n; j++)
AInverse[n*i+j] = 0;
ac[n*i+j] = A[n*i+j];
AInverse[n*i+i] = 1;
// The current pivot row is iPass.
// For each pass, first find the maximum element in the pivot column.
for (iPass = 0; iPass < n; iPass++)
imx = iPass;
for (irow = iPass; irow < n; irow++)
if (fabs(A[n*irow+iPass]) > fabs(A[n*imx+iPass])) imx = irow;
// Interchange the elements of row iPass and row imx in both A and AInverse.
if (imx != iPass)
for (icol = 0; icol < n; icol++)
temp = AInverse[n*iPass+icol];
AInverse[n*iPass+icol] = AInverse[n*imx+icol];
AInverse[n*imx+icol] = temp;
if (icol >= iPass)
temp = A[n*iPass+icol];
A[n*iPass+icol] = A[n*imx+icol];
A[n*imx+icol] = temp;
// The current pivot is now A[iPass][iPass].
// The determinant is the product of the pivot elements.
pivot = A[n*iPass+iPass];
det = det * pivot;
if (det == 0)
free(ac);
return 0;
// Normalize the pivot row by dividing by the pivot element.
AInverse[n*iPass+icol] = AInverse[n*iPass+icol] / pivot;
if (icol >= iPass) A[n*iPass+icol] = A[n*iPass+icol] / pivot;
for (irow = 0; irow < n; irow++)
// Add a multiple of the pivot row to each row. The multiple factor
// is chosen so that the element of A on the pivot column is 0.
if (irow != iPass) factor = A[n*irow+iPass];
if (irow != iPass)
AInverse[n*irow+icol] -= factor * AInverse[n*iPass+icol];
A[n*irow+icol] -= factor * A[n*iPass+icol];
free(ac);
return 1;
