发表于 2008-7-20 14:28:39
IO模拟程序搞不定啊,可以读ID,但读写页面不正常,读出来是FF,能不能传一下调好的程序
//写命令
void NFWrCmd(uint8 cmd)
OS_ENTER_CRITICAL();
NF_DPORT_OUT;
NF_ALE_CLR;
NF_nCS_CLR;
NF_CLE_SET;
NF_nWE_CLR;
FIO3SET |= (uint32)cmd;
NF_nWE_SET;
NF_CLE_CLR;
NF_ALE_SET;
OS_EXIT_CRITICAL();
//写地址
void NFWrAddr(uint8 addr)
NF_DPORT_OUT;
NF_nWE_SET;
NF_nCS_CLR;
NF_CLE_CLR;
NF_ALE_SET;
NF_nWE_CLR;
FIO3SET |= (uint32)addr;
NF_nWE_SET;
NF_BUSY_END; // wait busy end
NF_ALE_CLR;
OS_EXIT_CRITICAL();
//写数据
void NFWrDat(uint8 dat)
NF_DPORT_OUT;
NF_nWE_SET;
NF_CLE_CLR;
NF_nCS_CLR;
NF_ALE_CLR;
NF_nWE_CLR;
FIO3SET |= (uint32)dat;
NF_nWE_SET;
OS_EXIT_CRITICAL();
//读数据
uint8 NFRdDat(void)
uint8 Rdata;
NF_DPORT_IN;
NF_nWE_SET;
NF_CLE_CLR;
NF_ALE_CLR;
NF_nCS_CLR;
NF_nOE_CLR;
Rdata = (UINT8)( FIO3PIN );
NF_BUSY_END;
NF_nOE_SET;
OS_EXIT_CRITICAL();
return Rdata;
** 函数名: NF_ReadPage()
** 说 明: 读页面
void NF_ReadPage(uint32 Block, uint8 Page,uint8 *Buff)
uint16 i, j;
uint32 BlockPage;
uint8 HAdd;
uint8 MAdd;
uint8 LAdd;
uint8 *bufPt = Buff;
//每块32页,每页512字节
Page &= 0x1F; //[Page = A9,A10,A11,A12,A13]
//计算实际地址
BlockPage = (Block<<5) + Page; //[Block = A14 ...]
LAdd = (unsigned char)(BlockPage & 0xFF);
MAdd = (unsigned char)(BlockPage>>8 & 0xFF);
HAdd = (unsigned char)(BlockPage>>16 & 0xFF);
//读写NAND的时候,总线不可以变化,中断读写特殊寄存器可能引起总线跳变
NFWrCmd(0x00);
NFWrAddr(0x00);
//NFWriteAdd(HAdd, MAdd, LAdd);
NFWrAddr(LAdd);
NFWrAddr(MAdd);
NFWrAddr(HAdd);
//The 528 bytes of data within the selected page are
//transferred to the data registers in less than 12us(tR).
for (j=0; j<10; j++); //wait tWB(100ns)/////??????
NF_BUSY_END; // Wait tR(max 12us)
for (i=0;i<512;i++)
*bufPt++ = NFRdDat(); // Read one page
OS_EXIT_CRITICAL();//开中断
** 函数名: NF_WritePage()
** 说 明: 写页面
uint8 NF_WritePage(uint32 Block, uint8 Page, uint8 *Buff)
uint8 Status;
uint8 HAdd;
uint8 MAdd;
uint8 LAdd;
uint16 i;
uint32 BlockPage;
//每块32页,每页512字节
//计算实际地址
OS_ENTER_CRITICAL();//关中断
NFWrCmd(0x80);
NFWrAddr(0x00);
NFWrAddr(LAdd);
NFWrAddr(MAdd);
NFWrAddr(HAdd);
for (i=0;i<512;i++)
NFWrDat(*bufPt++); // Write one page to NFM from buffer
NFWrCmd(0x10);
//Read Staus Register
while (1)
{//Device Operation --- BIT6
NFWrCmd(0x70);
Status = NFRdDat();
if (Status & (1<<6))
{//Busy : "0" Ready : "1"
//Total Pass/Fail -- BIT0
NFWrCmd(0x70);;
Status = NFRdDat();
if (Status & (1<<0))
{//Fail : "1"
return 0;
{//Pass : "0"
OS_EXIT_CRITICAL();;//开中断
return 1;
