3楼
发表于 2004-12-2 17:27:51
只看该作者
我说的是不使用额外的芯片,直接用MAGE8模拟
我已经完成了。用试波器检测无误。
红外通讯函数(发送端)4M晶震
# include <iom8.h>
# include <macros.h>
#pragma interrupt_handler timer1_vof:9 //定时器1中断
#pragma interrupt_handler timer0_ovf_isr:10 //定时器0中断
/**************全局变量定义****************/
unsigned int time_counter=0; //定时器
unsigned int time_counter_end=0; //终止时间
char press_keys=0; //按键代码
unsigned char temp_signals=0; //要发送的数据
unsigned char signals=16;
/****************函数声明******************/
void timer1_int(void);
void timer0_init(void);
void port_int(void);
void delay(unsigned int times);
void timer1_vof(void);
void timer0_ovf_isr(void);
void send_signal(void);
void scan_key_press(void);
定时器
TCCR1B = 0x00; //stop
//TCNT1H = 0xd4; //setup
//TCNT1L = 0xce;
TCNT1H=0xf0;
TCNT1L=0x60;
TCCR1A = 0x00;
TCCR1B = 0x01; //start Timer
TIMSK = 0x04;
TCCR0 = 0x00; //stop
TCNT0 = 0xcb; //set count 38k*2
端口初始化
void port_int(void)
//发送端程序
PORTD=0x00;
DDRD=0xff;//
DDRB=0xff;
PORTB=0xff;
DDRB=0x00; //使用PB1-5作为按键输入
DDRC=0xff;
PORTC=0xff;
DDRC=0X00; //使用PC1-3作为按键输入
延时程序
//times 单位 ms
time_counter=1; //打开计数器
time_counter_end=times; //设置延时
res:
if (time_counter!=0)
goto res;
定时器中断处理
unsigned char a=0,b=0;
//逻辑自锁计数器
if (time_counter>0)
time_counter++;
if (time_counter>time_counter_end)
time_counter=0;
if (temp_signals!=0) //发送数据
PORTD|=(1<<7);
for (a=1;a<=10;a++)
for(b=1;b<=8;b++)
TCCR0|=((temp_signals)&(1<<(b-1)))>>(b-1); //发送38K载波
PORTD&=(~(1<<7));
TCNT0 = 0xcb; //REset count 38k*2
signals=~signals;
if (signals==16)
PORTD|=signals;
PORTD&=signals;
按键查询
{//返回按键值 press_keys
char a=0;
//测试B口
for(a=1;a<=5;a++)
if (((PINB&(1<<a))!=(1<<a)))
delay(10); //去陡
press_keys=a;
goto end_sub;
//测试C口
for (a=6;a<9;a++)
if (((PINC&(1<<(a-5)))!=(1<<(a-5))))
delay(10);
press_keys=a;
goto end_sub;
press_keys=0;
temp_signals=0; //不发送数据
TCCR0=0x00;
end_sub:
信号发送
temp_signals=(0xff<<(8-press_keys)); //使用步进码
主程序(查询方式)
timer1_int();
timer0_init();
port_int();
SEI();
TIMSK = 0b00000101; //timer interrupt sources
while(1) //等待中断
scan_key_press();
if (press_keys!=0)
send_signal();
