发表于 2008-7-2 08:53:49
我写过DS2433的程序,和DS2431一样.
下面是我的测试程序,可以通过串口看.
;***************读写DS2433
; Fosc=8M
.INCLUDE "M32DEF.INC"
.DEVICE ATmega32
;预定义
;**常量定义
;.EQU BAUDH =0X0 ;BAUD RATE:2400bps
;.EQU BAUDL =0Xcf
.EQU BAUDH =0X0 ;BAUD RATE:9600bps
.EQU BAUDL =0X33
.EQU DQ =PA0 ;1线数据口
.EQU OWDATA =PORTA
.EQU OWDIR =DDRA
.EQU OWPIN =PINA
;延时常量
.EQU TMR60USL =0XC3 ;
.EQU TMR60USH =0XFF
.EQU TMR500USL =0X0B
.EQU TMR500USH =0XFE
.EQU TMR30MSL =0XCF
.EQU TMR30MSH =0X8A
; ROM commands
.EQU RDROM =0X33 ;read serial number
.EQU MATCHROM =$55 ;match SN -- for multiple devices
.EQU SKIPROM =$CC ;ignore SN -- use for one device
; RAM commands
.EQU WRSP =$0F ; write DS2433 scratch pad
.EQU RDSP =$AA ; read DS2433 scratch pad
.EQU COPYSP =$55 ; copy DS2433 scratch pad to e2prom
.EQU RDE2P =$F0 ; read DS2433 E2Prom directly
.DEF STACKTEMP0 =R0
.DEF STACKTEMP1 =R1
.DEF COUNTER =R2
.DEF TEMP =R16
.DEF TVALUE =R17
.DEF RVALUE =R18
.DEF TXBYTE =R19
.DEF RXBYTE =R20
.DSEG
.ORG 0X100
ADDR1: .BYTE 1
ADDR2: .BYTE 1
TA1: .BYTE 1
TA2: .BYTE 1
ES: .BYTE 1
CRCLO: .DB 1
CRCHI: .DB 1
.ORG 0X200
TXBUFFER: .DB 0X20
RXBUFFER: .DB 0X20
.CSEG
.ORG 0X00
RJMP MAIN
.ORG 0X12
.ORG 0X100
MAIN:
ldi R16,LOW(RAMEND) ;
out SPL,R16 ;
ldi R16,HIGH(RAMEND) ;
out SPH, R16 ;
RCALL InitSystem
RCALL InitUART
; "**********************************", CR,
; "* DS2433 - Demonstration program *", CR,
; "**********************************", CR, CR
LDI TEMP,106
LDI ZL,LOW(Title<<1)
LDI ZH,HIGH(Title<<1)
RCALL TerminalShowConst
LDI TEMP,0X20
RCALL ReadEeprom
RCALL TerminalShowAddress
LDI XL,LOW(RXBUFFER)
LDI XH,HIGH(RXBUFFER)
RCALL TerminalShowData32
CLR TEMP
STS ADDR1,TEMP
STS ADDR2,TEMP
LDI TEMP,32
MOV COUNTER,TEMP
LDI TEMP,0X50
RCALL ReadDataToMemory
RCALL TerminalShowStartWR
RCALL WrScratchPad
RCALL TerminalShowWrCRC
LDI XL,LOW(TXBUFFER)
LDI XH,HIGH(TXBUFFER)
RCALL TerminalShowStartRD
RCALL RdScratchPad
RCALL TerminalShowRdCRC
RCALL TerminalShowFlag
HALT:
RJMP HALT
;*********** SUBROUTINE ******************
InitSystem:
LDI TEMP,0X02 ;0B 0000 0010
OUT DDRD,TEMP
LDI TEMP,0X03
OUT PORTD,TEMP
LDI TEMP,0X01 ;PA0为输入
OUT PORTA,TEMP
CLR TEMP
OUT DDRA,TEMP
CLR TEMP
CLR STACKTEMP0
CLR STACKTEMP1
CLR TVALUE
CLR RVALUE
CLR TXBYTE
CLR RXBYTE
RET
InitUART:
LDI TEMP,BAUDH
OUT UBRRH,TEMP
LDI TEMP,BAUDL
OUT UBRRL,TEMP
ldi TEMP,0X0
OUT UCSRA,TEMP
LDI TEMP,(1<<RXEN)|(1<<TXEN);|(1<<u2x)
OUT UCSRB,TEMP
LDI TEMP,0X86
OUT UCSRC,TEMP
RET
UARTTransmit:
SBIS UCSRA,UDRE
RJMP UARTTransmit
OUT UDR,TVALUE
; CBI UCSRA,UDRE
RET
UARTReceive:
SBIS UCSRA,RXC
RJMP UARTReceive
IN TEMP,UCSRA
IN RVALUE,UDR
ANDI TEMP,(1<<FE)|(1<<DOR)|(1<<PE)
BRNE UARTReceive
RET
TerminalShowData: ;IN:TEMP,显示的字节数
LD R25,X+
RCALL HexConvertASSII
MOV TVALUE,R4
RCALL UARTTransmit
MOV TVALUE,R3
RCALL UARTTransmit
LDI TVALUE,32
RCALL UARTTransmit
DEC TEMP
BRNE TerminalShowData
RET
TerminalShowConst:
LPM TVALUE,Z+
RCALL UARTTransmit
; LPM TVALUE,Z
DEC TEMP
BRNE TerminalShowConst
RET
TerminalShowAddress:
LDI TEMP,10
LDI ZL,LOW(Address<<1)
LDI ZH,HIGH(Address<<1)
LDI TVALUE,48
RCALL UARTTransmit
LDI TVALUE,48
RCALL UARTTransmit
LDI TVALUE,48
RCALL UARTTransmit
LDI TVALUE,48
RCALL UARTTransmit
LDI TVALUE,72
RCALL UARTTransmit
LDI TVALUE,58
RCALL UARTTransmit
LDI TVALUE,13
RCALL UARTTransmit
RET
TerminalShowWrCRC:
LDI TVALUE,87
RCALL UARTTransmit
LDI TVALUE,114
RCALL UARTTransmit
LDI TVALUE,105
RCALL UARTTransmit
LDI TVALUE,116
RCALL UARTTransmit
LDI TVALUE,101
RCALL UARTTransmit
LDI TVALUE,32
RCALL UARTTransmit
LDI TVALUE,67
RCALL UARTTransmit
LDI TVALUE,82
RCALL UARTTransmit
LDI TVALUE,67
RCALL UARTTransmit
LDI TVALUE,58
RCALL UARTTransmit
LDS R25,CRCHI
MOV TVALUE,R4
RCALL UARTTransmit
MOV TVALUE,R3
RCALL UARTTransmit
LDS R25,CRCLO
MOV TVALUE,R4
RCALL UARTTransmit
MOV TVALUE,R3
RCALL UARTTransmit
LDI TVALUE,72
RCALL UARTTransmit
LDI TVALUE,13
RCALL UARTTransmit
RET
TerminalShowRdCRC:
LDI TVALUE,82
RCALL UARTTransmit
LDI TVALUE,101
RCALL UARTTransmit
LDI TVALUE,97
RCALL UARTTransmit
LDI TVALUE,100
RCALL UARTTransmit
LDI TVALUE,32
RCALL UARTTransmit
; LDI TVALUE,32
; RCALL UARTTransmit
LDI TVALUE,67
RCALL UARTTransmit
LDI TVALUE,82
RCALL UARTTransmit
LDI TVALUE,67
RCALL UARTTransmit
LDI TVALUE,58
RCALL UARTTransmit
LDS R25,CRCHI
MOV TVALUE,R4
RCALL UARTTransmit
MOV TVALUE,R3
RCALL UARTTransmit
LDS R25,CRCLO
MOV TVALUE,R4
RCALL UARTTransmit
MOV TVALUE,R3
RCALL UARTTransmit
LDI TVALUE,72
RCALL UARTTransmit
LDI TVALUE,13
RCALL UARTTransmit
RET
TerminalShowStartWR:
LDI TVALUE,83
RCALL UARTTransmit
LDI TVALUE,116
RCALL UARTTransmit
LDI TVALUE,97
RCALL UARTTransmit
LDI TVALUE,114
RCALL UARTTransmit
LDI TVALUE,116
RCALL UARTTransmit
LDI TVALUE,32
RCALL UARTTransmit
LDI TVALUE,119
RCALL UARTTransmit
LDI TVALUE,114
RCALL UARTTransmit
LDI TVALUE,105
RCALL UARTTransmit
LDI TVALUE,116
RCALL UARTTransmit
LDI TVALUE,105
RCALL UARTTransmit
LDI TVALUE,110
RCALL UARTTransmit
LDI TVALUE,103
RCALL UARTTransmit
LDI TVALUE,32
RCALL UARTTransmit
LDI TVALUE,46
RCALL UARTTransmit
LDI TVALUE,46
RCALL UARTTransmit
LDI TVALUE,46
RCALL UARTTransmit
LDI TVALUE,13
RCALL UARTTransmit
RET
TerminalShowStartRD:
LDI TVALUE,83 ;S
RCALL UARTTransmit
LDI TVALUE,116 ;t
RCALL UARTTransmit
LDI TVALUE,97 ;a
RCALL UARTTransmit
LDI TVALUE,114 ;r
RCALL UARTTransmit
LDI TVALUE,116 ;t
RCALL UARTTransmit
LDI TVALUE,32 ;space
RCALL UARTTransmit
LDI TVALUE,114
RCALL UARTTransmit
LDI TVALUE,101
RCALL UARTTransmit
LDI TVALUE,97
RCALL UARTTransmit
LDI TVALUE,100
RCALL UARTTransmit
LDI TVALUE,105
RCALL UARTTransmit
LDI TVALUE,110
RCALL UARTTransmit
LDI TVALUE,103
RCALL UARTTransmit
LDI TVALUE,32
RCALL UARTTransmit
LDI TVALUE,46
RCALL UARTTransmit
LDI TVALUE,46
RCALL UARTTransmit
LDI TVALUE,46
RCALL UARTTransmit
LDI TVALUE,13
RCALL UARTTransmit
RET
TerminalShowData32:
LDI TEMP,0X4
MOV COUNTER,TEMP
LOOP1:
LDI TEMP,0X8
LDI TVALUE,13
RCALL UARTTransmit
DEC COUNTER
BRNE LOOP1
LDI TVALUE,13
RCALL UARTTransmit
RET
TerminalShowFlag:
LDI TVALUE,84
RCALL UARTTransmit
LDI TVALUE,65
RCALL UARTTransmit
LDI TVALUE,49
RCALL UARTTransmit
LDI TVALUE,44
RCALL UARTTransmit
LDI TVALUE,84
RCALL UARTTransmit
LDI TVALUE,65
RCALL UARTTransmit
LDI TVALUE,50
RCALL UARTTransmit
LDI TVALUE,44
RCALL UARTTransmit
LDI TVALUE,69
RCALL UARTTransmit
LDI TVALUE,83
RCALL UARTTransmit
LDI TVALUE,58
RCALL UARTTransmit
LDI TVALUE,32
RCALL UARTTransmit
LDS R25,TA1
MOV TVALUE,R4
RCALL UARTTransmit
MOV TVALUE,R3
RCALL UARTTransmit
LDI TVALUE,32
RCALL UARTTransmit
LDS R25,TA2
MOV TVALUE,R4
RCALL UARTTransmit
MOV TVALUE,R3
RCALL UARTTransmit
LDI TVALUE,32
RCALL UARTTransmit
LDS R25,ES
MOV TVALUE,R4
RCALL UARTTransmit
MOV TVALUE,R3
RCALL UARTTransmit
LDI TVALUE,13
RCALL UARTTransmit
RET
HexConvertASSII:
CLR R4
CLR R3
MOV R4,R25
ANDI R25,0X0F
CPI R25,0XA
BRSH GreaterNine
MOV R3,R25
LDI R25,48
; ADD R3,R25
RJMP HCANext
GreaterNine:
SUBI R25,0XA
MOV R3,R25
LDI R25,65
HCANext:
ADD R3,R25
SWAP R4
MOV R25,R4
ANDI r25,0X0F
CPI R25,0XA
BRSH GNAgain
MOV R4,R25
LDI R25,48
RJMP HCANextAgain
GNAgain:
SUBI R25,0XA
MOV R4,R25
LDI R25,65
HCANextAgain:
ADD R4,R25
RET
ReadDataToMemory:
RDTMLoop:
ST X+,TEMP
INC TEMP
DEC COUNTER
BRNE RDTMLoop
RET
SetBusHi:
MOV STACKTEMP0,TEMP
PUSH STACKTEMP0
IN TEMP,OWDIR ;1线端口置为输入
ANDI TEMP,0XFE
OUT OWDIR,TEMP
POP STACKTEMP0
MOV TEMP,STACKTEMP0
RET
SetBusLo: ;1线端口置为输出,输出0
MOV STACKTEMP0,TEMP
PUSH STACKTEMP0
IN TEMP,OWDIR
ORI TEMP,0X01
OUT OWDIR,TEMP
IN TEMP,OWDATA
ANDI TEMP,0XFE
OUT OWDATA,TEMP
POP STACKTEMP0
MOV TEMP,STACKTEMP0
RET
DS2433InitState: ;复位,握手
RCALL SetBusHi
RCALL SetBusLo
RCALL DEL_500US
RCALL SetBusHi
RCALL DEL_500US
RET
RstPulse: ;总线复位
RCALL SetBusHi
RCALL SetBusLo
RCALL DEL_500US
RCALL SetBusHi
RET
TxLo: ;输出0
RCALL SetBusLo
RCALL DEL_60US
RCALL SetBusHi
RCALL DEL_1US
RET
TxHi: ;输出1
RCALL SetBusLo
RCALL DEL_1US ;1us<tlow1<15us ;PB2置为输出,输出0
RCALL SetBusHi
RCALL DEL_60US
RCALL DEL_1US ;recovery time min 1us
RET
SendByte: ;向总线传输1字节数据
MOV STACKTEMP0,TEMP
PUSH STACKTEMP0
LDI TEMP,0X8
CLC
RollSend:
ROR TXBYTE
BRCS HiBitSend
RCALL TxLo
RJMP SLoop
HiBitSend:
RCALL TxHi
SLoop:
DEC TEMP
BRNE RollSend
POP STACKTEMP0
MOV TEMP,STACKTEMP0
RET
ReceiveByte: ;从总线上接收1字节数据
MOV STACKTEMP0,TEMP
PUSH STACKTEMP0
LDI TEMP,0X8
CLR RXBYTE
RLoop:
RCALL SetBusLo
RCALL DEL_1US
RCALL SetBusHi
RCALL DEL_15US ; delay to sample reliable bit
RRepeat:
SBIS OWPIN,DQ
RJMP LoBitReceive
SEC
RJMP ReceiveBit
LoBitReceive:
SBIC OWPIN,DQ
RJMP RRepeat
CLC
ReceiveBit:
ROR RXBYTE
RCALL DEL_60US ; tdrv + trelease
DEC TEMP
BRNE RLoop
POP STACKTEMP0
MOV TEMP,STACKTEMP0
RET
WrScratchPad: ;传输32字节数据
MOV STACKTEMP0,TEMP
PUSH STACKTEMP0
RCALL DS2433InitState ;复位,握手
LDI TXBYTE,SKIPROM ; 0xCC
RCALL SendByte ; SkipROM ;向总线传送0xcc
LDI TXBYTE,WRSP ; write memory scratch pad, 0x0f
RCALL SendByte
LDS TXBYTE,ADDR1 ; starting address of memory scratch pad
RCALL SendByte
LDS TXBYTE,ADDR2
RCALL SendByte
LDI TEMP,0X20 ;以下向总线传输32字节的数据
WrLoop:
LD TXBYTE,X+
RCALL SendByte
; RCALL RstPulse
RCALL DEL_500US ; wait presence pulse
DEC TEMP
BRNE WrLoop
RCALL ReceiveByte
STS CRCLO,RXBYTE
RCALL ReceiveByte
STS CRCHI,RXBYTE
POP STACKTEMP0
MOV TEMP,STACKTEMP0
RET
RdScratchPad: ;读TA1,TA2,ES,DATA0~DATA31,CRCL,CRCH
MOV STACKTEMP0,TEMP
PUSH STACKTEMP0
LDI TXBYTE,SKIPROM
RCALL SendByte
LDI TXBYTE,RDSP
RCALL SendByte
; RCALL RstPulse
RCALL ReceiveByte
STS TA1,RXBYTE
RCALL ReceiveByte
STS TA2,RXBYTE
RCALL ReceiveByte
STS ES,RXBYTE
LDI TEMP,0X20
RdSLoop: ;读数据,32字节
RCALL ReceiveByte
ST X+,RXBYTE
DEC TEMP
BRNE RdSLoop
RCALL ReceiveByte
STS CRCLO,RXBYTE
RCALL ReceiveByte
STS CRCHI,RXBYTE
RCALL RstPulse
POP STACKTEMP0
MOV TEMP,STACKTEMP0
RET
ReadEeprom: ;IN:读字节数,TEMP
MOV STACKTEMP0,TEMP
PUSH STACKTEMP0
LDI TXBYTE,SKIPROM
RCALL SendByte
LDI TXBYTE,RDE2P
RCALL SendByte
LDS TXBYTE,ADDR1
RCALL SendByte
LDS TXBYTE,ADDR2
RCALL SendByte
; LDI TEMP,0X8
RdELoop:
RCALL ReceiveByte
ST X+,RXBYTE
DEC TEMP
BRNE RdELoop
RCALL RstPulse
POP STACKTEMP0
MOV TEMP,STACKTEMP0
RET
CopyEeprom:
MOV STACKTEMP0,TEMP
PUSH STACKTEMP0
LDI TXBYTE,SKIPROM
RCALL SendByte
LDI TXBYTE,COPYSP
RCALL SendByte
LDS TXBYTE,TA1
RCALL SendByte
LDS TXBYTE,TA2
RCALL SendByte
LDS TXBYTE,ES
RCALL SendByte
RCALL DEL_500US
CopyLoop:
RCALL ReceiveByte
LDI TEMP,0X55
EOR TEMP,RXBYTE
BREQ CopyOver
LDI TEMP,0XAA
EOR TEMP,RXBYTE
BRNE CopyLoop
CopyOver:
RCALL RstPulse
POP STACKTEMP0
MOV TEMP,STACKTEMP0
RET
DEL_1US:
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
RET
DEL_15US:
RCALL DEL_1US
RCALL DEL_1US
RCALL DEL_1US
RCALL DEL_1US
RCALL DEL_1US
RCALL DEL_1US
RCALL DEL_1US
RCALL DEL_1US
RCALL DEL_1US
RCALL DEL_1US
RCALL DEL_1US
RCALL DEL_1US
RCALL DEL_1US
RCALL DEL_1US
RET
DEL_60US:
MOV STACKTEMP0,TEMP
PUSH STACKTEMP0
LDI TEMP,TMR60USH
OUT TCNT1H,TEMP
LDI TEMP,TMR60USL
OUT TCNT1L,TEMP
CLR TEMP
OUT TCCR1A,TEMP
LDI TEMP,0X2 ;系统时钟/8
OUT TCCR1B,TEMP
D60LOOP:
IN TEMP,TIFR
SBRS TEMP,TOV1
RJMP D60LOOP
CBR TEMP,0X04
OUT TIFR,TEMP
RCALL STOP_TIMER
POP STACKTEMP0
MOV TEMP,STACKTEMP0
RET
DEL_500US:
MOV STACKTEMP0,TEMP
PUSH STACKTEMP0
LDI TEMP,TMR500USH
OUT TCNT1H,TEMP
LDI TEMP,TMR500USL
OUT TCNT1L,TEMP
CLR TEMP
OUT TCCR1A,TEMP
OUT TCCR1B,TEMP
D500LOOP:
IN TEMP,TIFR
SBRS TEMP,TOV1
RJMP D500LOOP
CBR TEMP,0X04
OUT TIFR,TEMP
RCALL STOP_TIMER
POP STACKTEMP0
MOV TEMP,STACKTEMP0
RET
DEL_30MS:
MOV STACKTEMP0,TEMP
PUSH STACKTEMP0
LDI TEMP,TMR30MSH
OUT TCNT1H,TEMP
LDI TEMP,TMR30MSL
OUT TCNT1L,TEMP
CLR TEMP
OUT TCCR1A,TEMP
OUT TCCR1B,TEMP
D30LOOP:
IN TEMP,TIFR
SBRS TEMP,TOV1
RJMP D30LOOP
CBR TEMP,0X04
OUT TIFR,TEMP
RCALL STOP_TIMER
POP STACKTEMP0
MOV TEMP,STACKTEMP0
RET
STOP_TIMER:
CLR TEMP
OUT TCCR1B,TEMP
CLI
RET
.CSEG
.ORG 0X500
Title:
.DB 42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42
.DB 42,42,13,42,32,32,32,32,32,32,32,32,32,32,32,32
.DB 68,83,50,52,51,51,32,32,32,32,32,32,32,32,32,32
.DB 32,32,32,32,42,13,42,42,42,42,42,42,42,42,42,42
.DB 42,42,42,42,42,42,42,42,13,13
.ORG 0X600
Address:
.DB 65,68,68,82,69,83,83,45,45,62
.EXIT
注释少点,不过子程序的名字或许能有些提示.
由于是测试的,可能比较乱.没改,助你参考吧. |
