回复: 3
用,AT89S52,DS1302做万年历,程序出了问题,看不懂,希望高手指点
发表于 2008-6-17 14:36:31 | 显示全部楼层 |阅读模式
PLAY1: MOV  A,#0FFH
       MOV  P2,A
       MOV  A,@R0
       MOV  DPTR,#TAB1        1475
       MOVC  A,@A+DPTR
       MOV   SBUF,A
       JNB   TI,$
       CLR   TI
       MOV   A,@R1
       MOV   DPTR,#TAB1      1481
       MOVC  A,@A+DPTR
       MOV  SBUF,A
       JNB  TI,$
       CLR TI
       MOV  A,R2
       MOV  DPTR,#TAB1      1487
       MOVC  A,@A+DPTR
       MOV  SBUF,A
       JNB  TI,$
       CLR  TI
       INC  R0
       INC  R1
       INC  R3
       MOV  A,R3
       SETB PSW.4
       MOV  R0,A
       MOV  A,@R0
       CLR  PSW.4
       MOV  R2,A
       MOV  A,R0
       CJNE   A,#78H,PLAY2
       MOV    R0,#50H
PLAY2: CJNE   A,#54H,PLAY3
       MOV    R0,#78H
PLAY3: MOV    A,R5
       MOV    P2,A
       LCALL  DL1MS
       MOV    A,R5
       JNB    ACC.6,PLAYOUT
       RL     A
       MOV    R5,A
       LJMP   PLAY1
PLAYOUT:SETB  P2.6
       RET
DL1MS: MOV    R6,#14H
DL1:   MOV    R7,#19H
DL2:   DJNZ   R7,DL2
       DJNZ   R6,DL1
       RET
AB1:   DB      03H,9FH,25H,0DH,99H
       DB      49H,41H,1FH,01H,09H,0FFH
TAB:   DB      35,15H,51H,00H,23,11H,52H,41H,42,12H,65H,00H
       DB      31,11H,32H,00H,21,42H,52H,21H,39,52H,25H,00H
       DB      28,25H,04H,71H,48,66H,42H,00H,37,33H,22H,00H
       DB      25,15H,24H,51H,44,05H,52H,00H,33,22H,65H,00H
       DB      22,21H,25H,41H,40,24H,52H,00H,30,52H,42H,91H
       DB      49,55H,05H,00H,38,26H,44H,00H,27,53H,50H,60H
       DB      46,53H,24H,00H,35,25H,54H,00H,24,41H,52H,41H
       DB      42,45H,25H,00H,31,24H,52H,00H,21,51H,12H,21H
       DB      40,55H,11H,00H,28,26H,21H,61H,47,26H,61H,00H
       DB      36,13H,31H,00H,25,05H,31H,51H,43,12H,54H,00H
       DB      33,51H,25H,00H,22,42H,25H,31H,41,32H,22H,00H
       DB      30,55H,02H,71H,49,55H,22H,00H,38,26H,62H,00H
       DB      27,13H,64H,60H,45,13H,32H,00H,34,12H,55H,00H
       DB      23,10H,53H,51H,42,22H,45H,00H,31,52H,22H,00H
       DB      21,52H,44H,21H,40,55H,44H,00H,29,26H,50H,71H
       DB      47,26H,64H,00H,36,25H,32H,00H,25,23H,32H,50H
       DB      44,44H,55H,00H,32,24H,45H,00H,22,55H,11H,30H
       END
  1475  error :A45  UNDEFINED SYMBOL
  1481   error :A45  UNDEFINED SYMBOL
  1487   error :A45  UNDEFINED SYMBOL
请问错在哪里,急!!!
发表于 2008-6-17 15:08:21 | 显示全部楼层
编译错误的话,这3个前要加;符号.
还有一个是TAB1,一个是TAB,这个也是错的,必须相同
发表于 2010-10-12 22:33:22 | 显示全部楼层
楼主牛X,沙发更牛。。。。。
GMT+8, 2024-8-25 18:42
