发表于 2008-6-13 15:53:24
之后有个统计任务,定义如下:
#if OS_TASK_STAT_EN > 0
static void OS_InitTaskStat (void)
#if OS_TASK_CREATE_EXT_EN > 0
#if OS_STK_GROWTH == 1
(void)OSTaskCreateExt(OS_TaskStat,
(void *)0, /* No args passed to OS_TaskStat()*/
&OSTaskStatStk[OS_TASK_STAT_STK_SIZE - 1], /* Set Top-Of-Stack */
OS_STAT_PRIO, /* One higher than the idle task */
OS_TASK_STAT_ID,
&OSTaskStatStk[0], /* Set Bottom-Of-Stack */
OS_TASK_STAT_STK_SIZE,
(void *)0, /* No TCB extension */
OS_TASK_OPT_STK_CHK | OS_TASK_OPT_STK_CLR); /* Enable stack checking + clear */
#else
&OSTaskStatStk[0], /* Set Top-Of-Stack */
OS_TASK_STAT_ID,
&OSTaskStatStk[OS_TASK_STAT_STK_SIZE - 1], /* Set Bottom-Of-Stack */
#else
(void)OSTaskCreate(OS_TaskStat,
OS_STAT_PRIO); /* One higher than the idle task */
#else
也就是创建统计任务,统计任务的优先级为比空闲任务低一级,统计任务每秒钟运行一次(如果使能)
到这里就完成了UCOSII的初始化工作,接下来主要讲述运行原理。 |
