楼主: AVR-BIN
思路决定出路--键盘扫描详解(只讲解决方法,无代码)
发表于 2008-12-1 14:48:20 | 显示全部楼层
学习
发表于 2008-12-1 15:11:54 | 显示全部楼层
学习
发表于 2008-12-1 19:25:17 | 显示全部楼层
不知道在这里上传资料还有没有意义,不管了,传吧!!是《匠人手记》之一,讲键盘的!
点击此处下载 ourdev_524776.pdf(文件大小:192K) (原文件名:键盘漫谈.pdf)
发表于 2008-12-4 08:45:42 | 显示全部楼层
一直关注
发表于 2008-12-4 11:43:49 | 显示全部楼层
谢谢诶分享。
发表于 2008-12-4 16:11:41 | 显示全部楼层
赚取积分,贴上我的项目中对键盘的处理,需要识别短按键,双击,长时间按键,和非常长时间按键。
 该函数由scheduler调度,10ms执行一次。
void vCOMTOutTimerCnt(void)
    /* Key input level changed */
    if (u8OPMMflSymbol != u8OPMMflLastSymbol)
        if(u8OPMMflSymbol)
            /* key pressed, so (re-)start timer */
            u16COMTOutTimer = (U16) 0x00;
            u8COMTOutActive = 0x01;
            /* key released => evaluate timer and send keypress info to BT */
            if(u8COMTOutActive)
                u8COMTOutActive = 0x00;
                if( u16COMTOutTimer>= COM_TIMER_TEN_SECONDS)
                    /* was a very long press */
                    u8COMMflButton |= COM_MFL_BTN_VLONG;
                    u8COMMflKeyQualified = 0x01;
                else if(    (u16COMTOutTimer < COM_TIMER_TEN_SECONDS)
                         && (u16COMTOutTimer>= COM_TIMER_TWO_SECONDS)
                    /* was a long press*/
                    u8COMMflButton |= COM_MFL_BTN_LONG;
                else if(    (u16COMTOutTimer < COM_TIMER_FIVE_SECONDS)
                         && ( 0x01 == u8COMMflKeyPressed)
                    /* already one short press seen, so make it a double press*/
                    u8COMMflButton &= ~(COM_MFL_BTN_SHORT);
                    u8COMMflButton |= COM_MFL_BTN_DOUBLE;
                else if(   (u16COMTOutTimer <= COM_TIMER_TWO_SECONDS)
                         &&( 0x00 == u8COMMflKeyPressed)
                    // was a short press
                    u8COMMflButton |= COM_MFL_BTN_SHORT;
                    u8COMMflKeyPressed = 0x01;
                    /*do nothing */
        /* store new state*/
        u8OPMMflLastSymbol = u8OPMMflSymbol;
    /* check if a key press a qualified */
    /* when time exceed two secend, not possible for double envent*/
    /* so release short presee event */
    if (    ( 0x01 == u8COMMflKeyQualified)
         || (    (u16COMTOutTimer>= COM_TIMER_TWO_SECONDS)
              && (u8COMMflButton & COM_MFL_BTN_SHORT)
        u8COMNewCANMsg |= COM_MFL_MSG;
        u8COMMflKeyQualified = 0x00;
        u8COMMflKeyPressed = 0x00;
本贴被 modelfly 编辑过,最后修改时间:2008-12-04,16:26:02.
发表于 2008-12-5 23:28:53 | 显示全部楼层
新手来学习了,谢谢!
发表于 2009-5-10 14:51:01 | 显示全部楼层
学习
发表于 2009-5-10 15:14:08 | 显示全部楼层
学习了,
发表于 2009-5-10 16:37:53 | 显示全部楼层
看过
发表于 2009-5-14 15:05:33 | 显示全部楼层
mark!
发表于 2009-5-14 20:08:44 | 显示全部楼层
我写程序的方法和结构没有超过10uS的延时子程序:
用一个定时器每100uS中断一次产生一个100uS的标志。
main_loop:
       setb     ie.7                            ;;开启总中断,即EA
main_1ms_work:                                  ;;1ms做一次的事情
       jnb      f_1ms_work,main_10ms_work       ;;有没有1ms的标示
       acall    tim_pross                       ;;时间处理,产生其它时间标示
       acall    led_scan
       acall    toubi_test
       acall    ir_in_test
       clr      f_1ms_work                      ;;做完1ms的事情清掉标志
main_10ms_work:                                 ;;10ms做一次的事情
       jnb      f_10ms_work,main_1s_work        ;;有没有10ms的标示
       acall    key_scan_pross
       acall    key_code_pross
       acall    led_updata_pross
       acall    eeprom_write_pross
       acall    lanquan_run_pross
       acall    music_pross
       clr      f_10ms_work
main_1s_work:
       jnb      f_1s_work,main_loop
       acall    game_pross
       clr      f_1s_work
       ajmp     main_loop
发表于 2009-5-14 20:27:18 | 显示全部楼层
顶到飞高
出675入8汤圆
发表于 2009-5-15 01:48:41 | 显示全部楼层
好贴,学习了,谢谢楼主引出
出675入8汤圆
发表于 2009-5-15 01:49:32 | 显示全部楼层
不赞成有不同的意见就打击别人,可以不发言走人啊
发表于 2009-5-15 08:51:35 | 显示全部楼层
只用一个变量记录按下时间就可以了,不用什么标志变量
只读一个按键的:
unsigned  char  cnt_key;
if(!(PIND&(1<<0)))  //--低电平有效,PD0是否为低电平
  if(cnt_key<50)  cnt_key += 1;
  if(cnt_key==50)
   按键有效
   cnt_key = 55;  //--cnt_key只要大于按下按键有效值,连按时只判cnt_key是否为55
发表于 2009-5-15 09:43:30 | 显示全部楼层
85楼 程序最简单明了 佩服!
只是在最后 if((Key_flg == SHORT_FLG) || (Key_flg == LONG_FLG))  是不是该加个重复标志位 改成
if((Key_flg == SHORT_FLG) || (Key_flg == LONG_FLG)||(Key_flg==REPEAT_FLG))
发表于 2009-5-15 12:30:08 | 显示全部楼层
mark
发表于 2009-5-15 12:45:24 | 显示全部楼层
看资源和具体情况而定,无定法!
发表于 2009-5-15 15:14:03 | 显示全部楼层
记号
发表于 2009-5-15 16:29:24 | 显示全部楼层
好东西,MARK
感谢各位网友... ...
发表于 2009-5-15 18:57:15 | 显示全部楼层
mark
发表于 2009-5-16 10:54:39 | 显示全部楼层
如果有键盘中断的就更简单了。比如非利普和98系列单片机,在IO口为1时设其为0产生中断,当其按下后设其为1产生中断。我有个东西就是这样做的,不要说长按,就是按几天也没问题,还可以做到低功耗,不管按不按,电流都不会超下10UA。其实AVR的外部中断也可以做。
发表于 2009-5-17 07:23:33 | 显示全部楼层
mark.
发表于 2009-5-18 22:15:19 | 显示全部楼层
学习学习。
发表于 2009-5-19 10:45:46 | 显示全部楼层
学习学习
发表于 2009-5-19 11:28:13 | 显示全部楼层
具体情况具体分析,哪有什么固定的方法.
发表于 2009-5-22 13:03:01 | 显示全部楼层
这么好的帖子怎么能够沉下去呢。我不想发表什么,顶上去再说。
发表于 2009-5-22 13:31:23 | 显示全部楼层
记号
发表于 2009-5-22 23:02:02 | 显示全部楼层
mark
发表于 2009-5-22 23:33:26 | 显示全部楼层
mark
发表于 2009-5-22 23:52:58 | 显示全部楼层
mark
发表于 2009-5-23 13:04:19 | 显示全部楼层
留个记号,以后来学习
发表于 2009-5-23 22:19:31 | 显示全部楼层
学习一下
发表于 2009-5-23 22:58:41 | 显示全部楼层
代码来了。主程序采用定时器,1ms扫描一次。如果一个键按下不放1S钟后就以3次每秒的速度返回该键值,相当于快进。
原理图稍后上传,用的是8位LED和键盘共用的。
void KEYBOARD_INT(void)
//键盘端口初始化
_PA4=0;
DDR_PA4=1;
_PA0=1;
_PA1=1;
_PA2=1;
_PA3=1;
DDR_PA0=0;
DDR_PA1=0;
DDR_PA2=0;
DDR_PA3=0;
_PC2=1;
_PC3=1;
_PC4=1;
_PC5=1;
DDR_PC2=0;
DDR_PC3=0;
DDR_PC4=0;
DDR_PC5=0;
//键盘读取
unsigned char KEYBOARD_ONE(void)
unsigned char temp;
KEYBOARD_INT();
asm("nop");
asm("nop");
asm("nop");
    temp=PINA&0X0F;
    temp=temp|(0XF0&((PINC&0b00111100)<<2));
    temp=~temp;
_PA4=1;
return(temp);
//键盘值处理
//DATA[0]        键盘实际返回值
//DATA[1]   键盘按住时连续返回值
//DATA[2]        键盘中间存储用
//DATA[3]   键盘延时计数
//DATA[4]   键盘按住时延时一秒用
void KEYBOARD(unsigned char  *DATA)
unsigned char temp;
temp=KEYBOARD_ONE();
if(temp==0)
    DATA[0]=0;
        DATA[1]=0;
        DATA[2]=0;
    DATA[3]=0;
        DATA[4]=0;
        DATA[5]=0;
   if(DATA[2]!=temp)  {DATA[2]=temp; DATA[3]=0;}
   if((DATA[2]==temp)&(DATA[3]<11))
      DATA[3]++;
       if(DATA[3]==10) {DATA[0]=temp;}
       if(DATA[3]==11) {DATA[0]=0;}
        if((DATA[2]!=0)&(DATA[3]==11))
            DATA[4]++;
                 if((DATA[4]>254)&(DATA[5]<6)){DATA[5]++;DATA[4]=0;}
                 if(DATA[5]>5)
             if(DATA[0]!=0) DATA[0]=0;
             DATA[1]++;
             if(DATA[1]>150) {DATA[0]=DATA[2]; DATA[1]=0;}
发表于 2009-5-25 15:51:57 | 显示全部楼层
mark一下,有时间慢慢看
发表于 2009-5-25 22:08:34 | 显示全部楼层
MARK
按键的学问也蛮多的!!!
发表于 2009-5-26 12:24:09 | 显示全部楼层
先记下,有时间再看,学习了
发表于 2009-5-26 15:33:54 | 显示全部楼层
正在做个东西,要24~25个键,不知道怎么处理好.
发表于 2009-6-1 11:07:14 | 显示全部楼层
不错的贴,看看
发表于 2009-6-1 15:17:11 | 显示全部楼层
呵呵~做个记号,有些和我不一样的思路呢。。
发表于 2009-6-1 17:13:26 | 显示全部楼层
再来几张在os中应用的帖子,基本键盘方面上此帖无敌。
发表于 2009-6-2 10:58:42 | 显示全部楼层
学习学习,谢谢分享!
发表于 2009-6-3 14:01:28 | 显示全部楼层
自己的思路,而且一直在用,基于中断和OS的。
开键盘中断--> 中断程序 --> YES(有效)启动键盘分析任务 --> 启动键盘事件处理任务 --> 键盘分析任务延时--> 开键盘中断并挂起
        (相当于防抖)
发表于 2009-7-12 19:36:31 | 显示全部楼层
很好很强大
发表于 2009-7-13 10:41:07 | 显示全部楼层
mark
发表于 2009-7-13 14:06:32 | 显示全部楼层
52楼的比较简洁,一般的键盘应用够了。
发表于 2009-7-13 19:05:17 | 显示全部楼层
好帖
发表于 2009-7-14 10:29:59 | 显示全部楼层
好贴啊,顶上去啊
发表于 2009-8-9 13:49:37 | 显示全部楼层
mark
发表于 2009-8-9 14:03:21 | 显示全部楼层
這樣基本的東西也要大費周章討論?
发表于 2009-8-9 14:08:32 | 显示全部楼层
发表于 2009-8-9 23:14:35 | 显示全部楼层
我觉得,键盘扫描可以参考PS/2键盘的做法,
PS/2键盘是:按一下立马就返回通码,在等一段时间以后,如果还是键按着的,就以一定频率连续返回键值,直道按键松开返回一个断码。
对于单片机扫描的键盘可以这样:按键按下立即开定时器,在消抖动之后立马返回键值,一段时间以后,如果还是按着键,就连续返回键值,直道按键断开,断开后关定时器。整个过程以定时器作为时间参考!
发表于 2009-8-9 23:19:35 | 显示全部楼层
很好的东东
发表于 2009-8-10 01:11:33 | 显示全部楼层
void keydeal()
{             if(keyflag)//keyflag==1表明先前的是高电平,才能进入到下面的处理
             {if(key==0){.........;   keyflag=0;}}//由高到低的时候就进行一些处理,这只是一个变化的时候生效,其它 时候没有效果,不会让CPU苦等
        else if(key!=0)keyflag=1;//高电平的时候把标志置一
出10入10汤圆
发表于 2009-8-10 16:20:13 | 显示全部楼层
本人菜鸟,只能看看各位高手解惑!留个爪印
发表于 2009-8-10 19:18:21 | 显示全部楼层
受益匪浅,记号
发表于 2009-8-10 19:18:41 | 显示全部楼层
好帖,顶起
发表于 2009-8-11 10:58:38 | 显示全部楼层
mark
发表于 2009-8-14 11:12:56 | 显示全部楼层
太深了,慢慢学习
发表于 2009-8-18 12:36:22 | 显示全部楼层
学习
发表于 2009-8-18 13:30:14 | 显示全部楼层
我觉得的楼主这个贴子对我们初学这来说是很不错的,
不管提出来的问题有多么菜,能把问题提出来加以讨论是值得我们学习的
我反对2楼和20楼这样的等等此类的所谓的"高手",去攻击别人,去贬低别人,说别人怎么混乱,说别人怎么混乱
这算什么呢,与其把时间浪费在攻击别人上
还不如把时间用在你的更好的方法写出来让大家共同拜读一下.
我说明一下,我跟楼主根本不认识,我只不过是看不惯论坛中总有那么一些人,老是去损人,贬低人.
我不知道他们这样做是不是来显示他们的水平很高,
这些损人,贬人的词汇对初学者来说一点帮助都没有,而是浪费了我们的阅读时间.
我发自内心的建议在论坛中能做一些有意义的讨论
也能让我们这些初学者
能多多学到点实用的东西
我们只想学习有意义的东西我们不想学习如何损人!!
发表于 2009-8-18 17:38:11 | 显示全部楼层
好东西,先记下,回头慢慢看大家的方法,也把自己的方法分享给大家。
发表于 2009-9-14 16:46:44 | 显示全部楼层
mark~~~
发表于 2009-9-14 18:46:19 | 显示全部楼层
mark
发表于 2009-9-16 17:26:18 | 显示全部楼层
贴一个偶最近用的一个代码,这是用的RTOS(RTX)的代码。
主要功能是读取单击或者按着不动(按着不动,就500ms发送一次KEY_CHANGE消息)。
检测到按钮事件之后,就把按钮事件发送到消息队列里面了。
__task void KeyProcessTask (void)
        u8 vk_code, temp_key;
        u8 last_vk_code = 0;
        for(;;)
                //wait 50ms to recheck KeyValue
                os_dly_wait(50);
                vk_code = GetKeyValue();
                if(vk_code != last_vk_code)
                        //Wait a moment to recheck
                        os_dly_wait(50);
                        temp_key = GetKeyValue();
                        if(temp_key == vk_code)
                                //Send a new Key Change Message
                                //if The KeyMailBox is Full , then TimeOut
                                os_PostMessage(KeyMailBox, MSG_KEY_CHANGE, vk_code, 0);
                        if(vk_code )
                                //Wait a moment to resend Key
                                os_dly_wait(500);
发表于 2009-9-20 14:03:52 | 显示全部楼层
m1
发表于 2009-9-24 01:22:18 | 显示全部楼层
谢谢
发表于 2009-9-30 10:28:59 | 显示全部楼层
学习
发表于 2009-9-30 13:29:26 | 显示全部楼层
技术人员都这样,相互不服气。至少口头上是这样。
其实解决一个问题,不要去批评|打击|评论别人的方案,每个人把自己的方案写出来,各位网友自己会判断优劣的,或者根据需要选取自己所要的方案。
发表于 2009-9-30 14:22:06 | 显示全部楼层
typedef struct
    BTN_CODE code;
    BTN_AGE  age;
    BTN_STATUS status;
} BUTTON;
长短按触发age可配置.... 不要浪费定时器,更不要死等去抖!
发表于 2009-9-30 14:30:17 | 显示全部楼层
MARK
发表于 2009-9-30 16:41:35 | 显示全部楼层
标。。。。。个记
发表于 2009-9-30 17:01:11 | 显示全部楼层
mark
发表于 2009-10-1 17:16:11 | 显示全部楼层
非常感谢,学习了
发表于 2009-10-7 17:15:35 | 显示全部楼层
學習了,謝謝!
发表于 2009-10-7 17:32:31 | 显示全部楼层
不得不顶,受教了……
发表于 2009-10-7 19:24:04 | 显示全部楼层
学习
标记
发表于 2009-10-7 20:31:02 | 显示全部楼层
这个讨论值得收藏
发表于 2009-10-7 21:08:51 | 显示全部楼层
关注
发表于 2009-10-8 00:12:27 | 显示全部楼层
我用的也是7楼的做法:“键盘扫描不用傻等,只要定时地扫描一次,无论有没按下,都把键值记下。连续几次键值相等,证明按键可靠。”
之外还需要一个历史有效键值记忆。一旦得到了可靠的新键值,则与历史有效键值比较,如果相等,则返回空键值;如果不相等,则返回新键值,并更新历史有效键值记忆。
这样即使是由于按键释放得到的新键值,也照样返回该新键值。反正该新键值应该与空键值相等,在按键响应时自然会放弃。
发表于 2009-10-8 04:28:28 | 显示全部楼层
又通看了全部帖子。支持85楼。
发表于 2009-10-10 11:48:35 | 显示全部楼层
发表于 2009-10-10 13:07:48 | 显示全部楼层
现在只会简单的,把它看完先
发表于 2009-12-8 23:08:32 | 显示全部楼层
收藏
发表于 2009-12-14 14:19:19 | 显示全部楼层
还得多读即便学习学习
发表于 2009-12-14 15:14:18 | 显示全部楼层
刚写的一段,还没验证。 先贴上来。很耗内存。 还在想好的按键处理方法…… 真是一门大学问
static UINT8      last_button_state = 0;
static UINT8      state = 0;
static UINT8      button_state[NUMBER_OF_BUTTONS];
static UINT8 debounce(UINT8 ButtonStat,UINT8 ButtonFlagMask)
    UINT8 debounce_tmp = ButtonStat;
    UINT8 Button_save  = ButtonStat;
    ButtonStat >>= BIN_INDEX_RC;      // ButtonStat / (2 ^ BIN_INDEX_RC)
        // Debounce_tmp = (2 ^ BIN_INDEX_RC - 1) / (2 ^ BIN_INDEX_RC) * ButtonStat
    debounce_tmp -= ButtonStat;
    if(ButtonFlagMask)
            // Debounce_tmp += 1/ (2 ^ BIN_INDEX_RC) * now button state
        debounce_tmp += 0xFF >> BIN_INDEX_RC;
    debounce_tmp &= 0xFE;             // clear the last bit
    Button_save &= 0x01;
    debounce_tmp |= Button_save;      // keep the last bit status
    if(debounce_tmp >= SCHMITT_HIGH_THRESH)
        debounce_tmp |= 0x01;         // The button is triggle
    if(debounce_tmp <= SCHMITT_LOW_THRESH)
       debounce_tmp &= ~0x01;        // The button is disable
        // else keep the last state
    return debounce_tmp;
static UINT8 get_button_state(void)
    UINT8 bs_reading;
    UINT8 bs = 0;
    if(PW_SW_Data_ADDR & PW_SW_MASK)
        bs |= PW_SW_MASK;
    if(RST_SW_Data_ADDR & RST_SW_MASK)
        bs |= RST_SW_MASK;
    return bs;
UINT8 buttons_get_trig(void)
    // Read button state
    UINT8 button_stat = get_button_state();
    UINT8 bs = 0;
    // Debounce buttons
    button_state[0] = debounce( button_state[0], button_stat & PW_SW_MASK );
    state |= (button_state[0] & 0x01) << 0;
    button_state[1] = debounce( button_state[1], button_stat & RST_SW_MASK );
    state |= (button_state[0] & 0x01) << 1;
    // Check for button state change
    if( last_button_state != state )
        bs = ((last_button_state ^ state) & state);
        last_button_state = state;
        return bs;
发表于 2009-12-14 15:18:41 | 显示全部楼层
mark
发表于 2009-12-17 17:25:26 | 显示全部楼层
获益匪浅,学学!请问一下,双击按键的程序改如何实现
发表于 2009-12-17 17:37:20 | 显示全部楼层
MARK 按键处理
发表于 2009-12-17 18:26:03 | 显示全部楼层
MARK,
发表于 2009-12-17 18:49:12 | 显示全部楼层
一直都有考虑按键处理的程序思路。MARK
发表于 2009-12-17 23:33:29 | 显示全部楼层
这个可以研究一下
发表于 2009-12-18 03:19:05 | 显示全部楼层
mark
发表于 2009-12-18 09:26:09 | 显示全部楼层
看来应该去看一看maochao的按键状态机去!
发表于 2009-12-18 10:05:08 | 显示全部楼层
转自http://bbs.ednchina.com/showtopic.aspx?id=149529
发个状态机方式扫描按键的程序,请高手指教!
结果 程序可以判断按键的长按、短按(又分为短按按下和短按抬起)
     以及按键复用功能(短按实现一个功能、长按实现一个功能)
先说一下我的思路:以什么方式读取按键都无所谓(不管是阵列式还是IO脚直接连)
最后将数据放到一个寄存器中 例如uint32 button_data_all; 32位的寄存器每一位代表一个按键,
然后用状态机的方式写一个扫描按键的程序void scan_button(struct button_module *P),
再为单片机设置一个10ms的定时中断,将扫描按键的程序放到定时中断的服务程序中,而每次进中10ms中断就好像是状态机的时钟CLK,在这个函数scan_button中会修改相应的长按、短按标志,在后面放置按键处理处理程序只需判断相应的标志即可,
文件meun.h
#ifndef __meun_H
#define __meun_H
//**************按键的结结构体************************
    uint8 short_flag;  //短按的标志 0xFF代表有短按按下 0x0F代表有短按抬起
    uint8 long_flag;   //长按的标志 0xFF代表有长按按下
    uint8 long_num;       //用于放置长按时间的寄存器
    uint8 state;
    uint8 key_num;     //按键的位置要扫面的是按键寄存器中的哪个按键
文件meun.c
文件名:neun.c
功能  :按键扫面及处理
创建者:ideality0214
//定义了两个按键button_enter,button_cannel
//button_enter在按键寄存器中的bit1位置
struct button_module button_enter={0,0,0,0,1};    //总计数器复位
struct button_module button_cannel={0,0,0,0,2};       //总计数器开
//***********************扫描按键*************************************
//short_flag 短按键 0xFF为有短按按下标志
//                    0x0F为有短按抬起标志
//long_flag  长按键 0xFF为有长按按下标志
    switch ((*P).state)
       { case 0x00:             //初始状态
                 if(~button_data_all&(uint32)(1<<(*P).key_num))
                   (*P).state=0x01;
                   (*P).state=0x00;
             }break;
         case 0x01:
                 if(~button_data_all&(uint32)(1<<(*P).key_num))    //确定有按键按下
                   (*P).state=0x02;
                   (*P).short_flag=0xFF;
                   (*P).state=0x00;
             }break;
            case 0x02:
                        (*P).long_num++;
                        if((*P).long_num==200)
                              (*P).long_num=0;
                              (*P).long_flag=0xFF;
                              (*P).state=0x04;
                   (*P).long_num=0x00;
                   (*P).state=0x03;
              }break;
            case 0x03:                                 //短按的松开的通道
                    (*P).short_flag&=0x0F;
                    (*P).state=0x00;
                }break;
            case 0x04:                                //长按
                   if(~button_data_all&(uint32)(1<<(*P).key_num)) //长按的持续
                        (*P).state=0x00;       //长按的松开
                }break;
            default :;
//******************************扫描需要按键按键********
void scan_button_all_button(void)
    scan_button(&button_enter);
    scan_button(&button_cannel);
    //可以任意添加想扫描的案件
//*******************按键enter定处理程序*********************************
void process_button_enter_short(void)
  if(button_enter.short_flag==0xFF)   //判断短按按下
       添加相应的处理程序
      button_enter.short_flag=0;
//*****************复用按键cannel的处理程序*********
void process_button_cannel_short(void)
  if(button_cannel.short_flag==0x0F)   //判断短按抬起
       添加相应的处理程序
      button_cannel.short_flag=0;
void process_button_cannel_long(void)
  if(button_cannel.long_flag==0xFF)   //判断长按按下
       添加相应的处理程序
      button_cannel.long_flag=0;
按需要修改if(button_cannel.long_flag==0xFF) 判断的标志即可,退出程序是一定要将标志清零
然后将这些函数添加到10ms中断的服务程序
void service_10ms(void)
         read_button();       //读取按键更新按键寄存器button_data_all的值
         scan_button_all_button();    //扫面需要的按键
         process_button_enter_short(); //按键enter处理程序
         process_button_cannel_short();//复用按键cannel短按抬起处理程序
         process_button_cannel_long(); //复用按键cannel长按按下处理程序
以上只是举了个两个按键的例子,
如需更多的按键只需定义结构struct button_module,将其加到 scan_button_all_button();函数中,编写相应的按键服务程序
发表于 2009-12-18 11:21:55 | 显示全部楼层
自从学习了马老师按键的状态机,我才知道什么是实用的按键程序。下面是本人用于项目的按键扫描。
其中包括一个按键是单发的,二个是连_发的,连_发的时间SPEED_INC_DEC设定,而按键去抖时间由KEY_DELAY确定(实际即是在主程序的循环次数,根据实际设定)
/*4 key state in key FSM mode*/
enum
   KEY_STATE_0=0,  //wait trigger
   KEY_STATE_1,           //key press wait to comfirm
   KEY_STATE_2,           //delay count_1
   KEY_STATE_3           //delay count_2
//key dely 1s,Sequence key trigger time delay 500ms
#define SPEED_INC_DEC             200
#define KEY_DELAY                500
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
* Function Name  : KEYS_Init
* Description    : Init GPIOs for joystick/button management
* Input          : None
* Output         : None
* Return         : None
void KEYS_Init(void)
  /* EnableGPIOBclock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  GPIO_StructInit(&GPIO_InitStructure);
  /*Key GPIOs configuration*/
  /*Input pull up-mode can save Res*/
  GPIO_InitStructure.GPIO_Pin = KEY_ON_BIT|KEY_PLUS_BIT|KEY_MINUS_BIT;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  GPIO_Init(KEY_PORT, &GPIO_InitStructure);
* Function Name  : KEYS_Read
* Description    : Reads key from demoboard.FSM detect the key pad
* Input          : None
* Output         : None
* Return         : Return key_value
u8 KEYS_Read (void)
  static u8 key_state=        KEY_STATE_0;
  static u32 bKey_Port_current;
  static u32 bKey_Port_previous=KEY_MASK;
  u8 key_return=NOTHING;
  bKey_Port_current= KEY_MASK&GPIO_ReadInputData(KEY_PORT);
  switch(key_state)
          case KEY_STATE_0:
        //key press waite comfirm
                 if((bKey_Port_current!=KEY_MASK)/*&&(bKey_Port_current==bKey_Port_previous)*/) key_state=KEY_STATE_1;
        case KEY_STATE_1:
        //real key press,turn to delay_cout1
                 if(bKey_Port_previous==bKey_Port_current)
                        { //ONOFF not use sequence trigger mode
                         if(!(bKey_Port_current&KEY_ON_BIT)) {key_return=ONOFF;DelayTimer(200);}
                         key_state=KEY_STATE_2;
                         StartTimer(TIMERKEY,KEY_DELAY);
                else key_state=KEY_STATE_0;
           case KEY_STATE_2:
        //real key press,and no delay for 1s
                if(bKey_Port_current==KEY_MASK)
                 {        //PLUS,MINUS key 1/1,ONOFF key 1/0,iput(1:0 off:ON)/output
                  if(!(bKey_Port_previous&KEY_PLUS_BIT))                 key_return=PLUS;
                  else if(!(bKey_Port_previous&KEY_MINUS_BIT))         key_return=MINUS;
           else if(ReadTimer(TIMERKEY)==OK)
                        { //PLUS,MINUS key 0/2,ONOFF key 0/0
                         if(!(bKey_Port_current&KEY_ON_BIT)) break;
                         if(!(bKey_Port_current&KEY_PLUS_BIT))                  key_return=PLUS;
                     else if(!(bKey_Port_current&KEY_MINUS_BIT)) key_return=MINUS;
                         key_state=KEY_STATE_3;
                           StartTimer(TIMERKEY,SPEED_INC_DEC);
        case KEY_STATE_3:
                                //PLUS,MINUS 0/2
                 if((bKey_Port_previous==bKey_Port_current)&&(ReadTimer(TIMERKEY)==OK))
                else if(bKey_Port_previous!=bKey_Port_current)        //if(bKey_Port_previous!=bKey_Port_current) must used
                         StopTimer(TIMERKEY);
  bKey_Port_previous=bKey_Port_current;
  return key_return;
发表于 2009-12-30 22:46:02 | 显示全部楼层
mark
发表于 2009-12-31 01:01:35 | 显示全部楼层
学习
出0入85汤圆
发表于 2009-12-31 13:02:23 | 显示全部楼层
mark
GMT+8, 2024-8-25 23:17
