以下是我用AT89S52控制TEA5767的收音程序,毕业设计做这个题目, 硬件部分还有2822的耳机驱动部分,都是由的3V供电,
经测试能收到电台,但是杂音非常大,杂音比电台信号还强,请各位大侠帮忙看看是不是程序由问题啊??谢谢!!
开始以为是硬件电路的干扰,但是硬件电路已经修改和试验过很多次,杂音还是非常大,写入程序后断开52的晶振 也试过,可是还不行,后来感觉是程序由问题,但是小弟才疏学浅,请各位帮帮忙,看看我的程序,谢谢!
#include"AT89X52.H"
unsigned int iic_delay_time = 60;
sbit scl=P2^6;
sbit sda=P2^7;
sbit INT_0=P3^2;
sbit INT_1=P3^3;
sbit INT_2=P3^4;
sbit have=P0^0;
#define max_freq 108000
#define min_freq 87500
unsigned char radio_write_data[5]; //要写入TEA5767的数据
unsigned char radio_read_data[5]; //TEA5767读出的状态
unsigned int default_pll=0x2d56;//0x2d56; //默认存台的pll,95.3MHz 江苏交广
unsigned int pll;
unsigned long frequency;
//unsigned int max_pll=0x339b; //108MHz时的pll,
//unsigned int min_pll=0x9000; //70MHz时的pll`
// delay
void iic_delay(unsigned int m)
unsigned int n;
for(n=0;n<m;n++);
//启动I2C总线的函数,当scl为高电平时使sda产生一个负跳变
void iic_start()
sda=1;
scl=1;
iic_delay(iic_delay_time);
sda=0;
scl=0;
iic_delay(iic_delay_time/2);
//终止I2C总线,当scl为高电平时使sda产生一个正跳变
void iic_stop()
sda=0;
scl=1;
sda=1;
//发送应答信号
void iic_ack()
sda=0;
scl=1;
scl=0;
sda=1;
//等待应答信号
bit waitack(void)
unsigned char errtime=255;//因故障接收方无ACK,超时值为25。
sda=1;
while(sda)
errtime--;
if (!errtime)
iic_stop();
return 0;
scl=1;
scl=0;
return 1;
//发送一个字节
void iic_write8bit(unsigned char input)
unsigned char temp;
for(temp=0;temp<8;temp++)
if((input<<temp)&0x80)
sda=1;
sda=0;
scl=1;
scl=0;
//读一个字节
unsigned char iic_read8bit()
unsigned char temp,rbyte=0;
scl=1;
if(sda)
rbyte=(rbyte<<1)+1;
rbyte=rbyte<<1;
scl=0;
return(rbyte);
//由频率计算PLL
void get_pll(void)
unsigned char hlsi;
unsigned int twpll=0;
hlsi=radio_write_data[2]&0x10;
if (hlsi)
pll=(unsigned int)((float)((frequency+225)*4)/(float)32.768); //频率单位:k
pll=(unsigned int)((float)((frequency-225)*4)/(float)32.768); //频率单位:k
//由PLL计算频率
void get_frequency(void)
unsigned char hlsi;
unsigned int npll=0;
npll=pll;
if (hlsi)
frequency=(unsigned long)((float)(npll)*(float)8.192-225); //频率单位:KHz
frequency=(unsigned long)((float)(npll)*(float)8.192+225); //频率单位:KHz
//写5767
void radio_write(void)
unsigned char i;
iic_start();
iic_write8bit(0xc0); //TEA5767写地址
waitack();
for(i=0;i<5;i++)
iic_write8bit(radio_write_data);
waitack();
iic_stop();
//读TEA5767状态,并转换成频率
void radio_read(void)
unsigned char i;
unsigned char temp_l,temp_h;
pll=0;
iic_start();
iic_write8bit(0xc1); //TEA5767读地址
waitack();
for(i=0;i<5;i++)
radio_read_data=iic_read8bit();
iic_ack();
iic_stop();
temp_l=radio_read_data[1];
temp_h=radio_read_data[0];
temp_h&=0x3f;
pll=temp_h*256+temp_l;
get_frequency();
//手动设置频率,mode=1,+0.1MHz; mode=0:-0.1MHz ,不用考虑TEA5767用于搜台的相关位:SM,SUD
void search()
radio_read();
frequency+=100;
if(frequency>max_freq)
frequency=min_freq;
get_pll();
radio_write_data[0]=pll/256;
radio_write_data[1]=pll%256;
radio_write_data[2]=0x20;
radio_write_data[3]=0x11;
radio_write_data[4]=0x00;
radio_write();
//自动搜台,频率增加搜台
void auto_searchup()
radio_read();
frequency=min_freq;
get_pll();
radio_write_data[2]=0xa0;
radio_write_data[0]=pll/256+0x40;
radio_write();
radio_read();
//自动搜台,频率减小搜台
void auto_searchdown()
radio_read();
if(frequency<min_freq)
frequency=max_freq;
get_pll();
radio_write();
radio_read();
void delay(void)
unsigned char i,j;
for(i=20;i>0;i++)
for(j=248;j>0;j--);
//向上搜台
void key_process0()
delay();
if(INT_0==0)
auto_searchup();
//向下搜台
void key_process1()
delay();
if(INT_1==0)
auto_searchdown();
//手动搜台
key_process2()
delay();
if(INT_2==0)
search();
void main()
unsigned char radio_write_data[5]={0x2d,0x56,0x20,0x11,0x00};
radio_write();
radio_read();
if((radio_read_data[0]&0x80)) //搜台成功标志
have=0;
if(INT_0==0)
key_process0();
if(INT_1==0)
key_process1();
/*************手动搜台*******************************************************************/
if(INT_2==0)
key_process2();
