发表于 2009-9-1 10:09:17
14 楼太对拉. 贴个参考的程序, 有啥问题自己再调调哈,是LCD1602显示的.
#include <reg51.h>
#include <intrins.h>
#define uint unsigned int
sbit DQ = P3^3; //定义DS18B20端口DQ
sbit BEEP=P3^7 ; //蜂鸣器驱动线
bit presence ;
sbit LCD_RS = P2^0;
sbit LCD_RW = P2^1;
sbit LCD_EN = P2^2;
uchar code cdis1[ ] = {" DS18B20 OK "};
uchar code cdis2[ ] = {" "};
uchar code cdis3[ ] = {" DS18B20 ERR0R "};
uchar code cdis4[ ] = {" PLEASE CHECK "};
unsigned char data display[2] = {0x00,0x00};
unsigned char data RomCode[8] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
unsigned char Temp;
unsigned char crc;
void beep();
#define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
void delay1(int ms)
unsigned char y;
while(ms--)
for(y = 0; y<250; y++)
_nop_();
_nop_();
_nop_();
_nop_();
/*检查LCD忙状态 */
/*lcd_busy为1时,忙,等待。lcd-busy为0时,闲,可写指令与数据。 */
bit lcd_busy()
bit result;
LCD_RS = 0;
LCD_RW = 1;
LCD_EN = 1;
delayNOP();
result = (bit)(P0&0x80);
LCD_EN = 0;
return(result);
/*写指令数据到LCD */
/*RS=L,RW=L,E=高脉冲,D0-D7=指令码。 */
void lcd_wcmd(uchar cmd)
while(lcd_busy());
LCD_RS = 0;
LCD_RW = 0;
LCD_EN = 0;
_nop_();
_nop_();
P0 = cmd;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
/*写显示数据到LCD */
/*RS=H,RW=L,E=高脉冲,D0-D7=数据。 */
void lcd_wdat(uchar dat)
while(lcd_busy());
LCD_RS = 1;
LCD_RW = 0;
LCD_EN = 0;
P0 = dat;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
/* LCD初始化设定 */
void lcd_init()
delay1(15);
lcd_wcmd(0x01); //清除LCD的显示内容
lcd_wcmd(0x38); //16*2显示,5*7点阵,8位数据
delay1(5);
lcd_wcmd(0x38);
delay1(5);
lcd_wcmd(0x38);
delay1(5);
lcd_wcmd(0x0c); //显示开,关光标
delay1(5);
lcd_wcmd(0x06); //移动光标
delay1(5);
delay1(5);
/* 设定显示位置 */
void lcd_pos(uchar pos)
lcd_wcmd(pos | 0x80); //数据指针=80+地址变量
/*us级延时函数 */
void Delay(unsigned int num)
while( --num );
/*初始化ds1820 */
Init_DS18B20(void)
DQ = 1; //DQ复位
Delay(8); //稍做延时
DQ = 0; //将DQ拉低
Delay(90); //精确延时 大于 480us
DQ = 1; //拉高总线
Delay(8);
presence = DQ; //读取存在信号
Delay(100);
DQ = 1;
return(presence); //返回信号,0=presence,1= no presence
/* 读一位(bit) */
uchar read_bit(void)
unsigned char i;
DQ = 0; //将DQ 拉低开始读时间隙
DQ = 1; // then return high
for (i=0; i<3; i++); // 延时15μs
return(DQ); // 返回 DQ 线上的电平值
/* 读一个字节 */
ReadOneChar(void)
unsigned char i = 0;
unsigned char dat = 0;
//for (i = 8; i > 0; i--)
// read_bit();
// DQ = 0; // 给脉冲信号
// dat >>= 1;
// DQ = 1; // 给脉冲信号
for (i=0;i<8;i++)
{ // 读取字节,每次读取一个字节
if(read_bit()) dat|=0x01<<i; // 然后将其左移
// if(DQ)
// dat |= 0x80;
Delay(4);
return (dat);
/* 写一位 */
void write_bit(char bitval) {
DQ = 0; // 将DQ 拉低开始写时间隙
if(bitval==1) DQ =1; // 如果写1,DQ 返回高电平
Delay(5); // 在时间隙内保持电平值,
DQ = 1; // Delay函数每次循环延时16μs,因此delay(5) = 104μs
/* 写一个字节 */
WriteOneChar(unsigned char dat)
unsigned char temp;
// for (i = 8; i > 0; i--)
for (i=0; i<8; i++) // 写入字节, 每次写入一位
// DQ = 0;
// DQ = dat&0x01;
// Delay(5);
// DQ = 1;
temp = dat>>i;
temp &= 0x01;
write_bit(temp);
// dat>>=1;
Delay(5);
/* 读取64位序列码 */
Read_RomCord(void)
unsigned char j;
Init_DS18B20();
WriteOneChar(0x33); // 读序列码的操作
for (j = 0; j < 8; j++)
RomCode[j] = ReadOneChar() ;
/*DS18B20的CRC8校验程序 */
uchar CRC8()
uchar i,x; uchar crcbuff;
crc=0;
for(x = 0; x <8; x++)
crcbuff=RomCode[x];
for(i = 0; i < 8; i++)
if(((crc ^ crcbuff)&0x01)==0)
crc >>= 1;
else {
crc ^= 0x18; //CRC=X8+X5+X4+1
crc >>= 1;
crc |= 0x80;
crcbuff >>= 1;
return crc;
/* 数据转换与显示 */
Disp_RomCode()
uchar j;
uchar H_num=0x40; //LCD第二行初始位置
for(j=0;j<8;j++)
Temp = RomCode[j];
display[0]=((Temp&0xf0)>>4);
if(display[0]>9)
{ display[0]=display[0]+0x37;}
else{display[0]=display[0]+0x30;}
lcd_pos(H_num);
lcd_wdat(display[0]); //高位数显示
H_num++;
display[1]=(Temp&0x0f);
if(display[1]>9)
{display[1]=display[1]+0x37;}
else {display[1]=display[1]+0x30;}
lcd_pos(H_num);
lcd_wdat(display[1]); //低位数显示
H_num++;
/* 蜂鸣器响一声 */
void beep()
unsigned char y;
for (y=0;y<100;y++)
Delay(60);
BEEP=!BEEP; //BEEP取反
BEEP=1; //关闭蜂鸣器
Delay(40000);
/* DS18B20 OK 显示菜单 */
void Ok_Menu ()
uchar m;
lcd_init(); //初始化LCD
lcd_pos(0); //设置显示位置为第一行的第1个字符
m = 0;
while(cdis1[m] != '\0')
{ //显示字符
lcd_wdat(cdis1[m]);
m++;
lcd_pos(0x40); //设置显示位置为第二行第1个字符
m = 0;
while(cdis2[m] != '\0')
lcd_wdat(cdis2[m]); //显示字符
m++;
/* DS18B20 ERROR 显示菜单 */
void Error_Menu ()
uchar m;
m = 0;
while(cdis3[m] != '\0')
{ //显示字符
lcd_wdat(cdis3[m]);
m++;
m = 0;
while(cdis4[m] != '\0')
lcd_wdat(cdis4[m]); //显示字符
m++;
/* 主函数 */
void main()
P0 = 0xff;
P2 = 0xff;
Ok_Menu ();
Read_RomCord(); //读取64位序列码
CRC8(); //CRC效验
if(crc==0) //CRC效验正确
Disp_RomCode(); //显示64位序列码
beep();
while(!presence)
Init_DS18B20();
delay1(1000);
Error_Menu ();
do
Init_DS18B20();
beep();
while(presence);
