CVAVR中有现成的函数,下面是说明和简单使用的例子
Maxim/Dallas Semiconductor DS1820/DS18S20 Temperature Sensors Functions
These functions are intended for easy interfacing between C programs and the DS1820/DS18S20 1 Wire bus temperature sensors.
The prototypes for these functions are placed in the file ds1820.h, located in the ..\INC subdirectory. This file must be #include -ed before using the functions.
The 1 Wire bus functions prototypes are automatically #include -ed with the ds1820.h.
Prior to #include -ing the ds1820.h file, you must declare which microcontroller port and port bit are used for communication with the DS1820/DS18S20 through the 1 Wire bus.
Example:
/* specify the port and bit used for the 1 Wire bus */
#asm
.equ __w1_port=0x18 ;PORTB
.equ __w1_bit=2
#endasm
/* include the DS1820/DS18S20 functions prototypes */
#include <ds1820.h>
The DS1820/DS18S20 functions are:
unsigned char ds1820_read_spd(unsigned char *addr)
this function reads the contents of the SPD for the DS1820/DS18S20 sensor with the ROM code stored in an array of 8 bytes located at address addr.
The functions returns the value 1 on succes and 0 in case of error.
If only one DS1820/DS18S20 sensor is used, no ROM code array is necessary and the pointer addr must be NULL (0).
The contents of the SPD will be stored in the structure:
struct __ds1820_scratch_pad_struct
unsigned char temp_lsb,temp_msb,
temp_high,temp_low,
res1,res2,
cnt_rem,cnt_c,
crc;
} __ds1820_scratch_pad;
defined in the ds1820.h header file.
int ds1820_temperature_10(unsigned char *addr)
this function returns the temperature of the DS1820/DS18S20 sensor with the ROM code stored in an array of 8 bytes located at address addr.
The temperature is measured in 癈 and is multiplied by 10. In case of error the function returns the value -9999.
If more several sensors are used, then the program must first identify the ROM codes for all the sensors. Only after that the ds1820_temperature_10 function may be used, with the addr pointer pointing to the array which holds the ROM code for the needed device.
Example:
#include <90s8515.h>
#asm
.equ __w1_bit=2
#endasm
#include <ds1820.h>
/* include the printf function prototype */
#include <stdio.h>
/* include the abs function prototype */
#include <math.h>
/* quartz crystal frequency [Hz] */
#define xtal 4000000L
/* Baud rate */
#define baud 9600
/* maximum number of DS1820/DS18S20 connected to the bus */
#define MAX_DEVICES 8
/* DS1820/DS18S20 devices ROM code storage area,
9 bytes are used for each device
(see the w1_search function description),
but only the first 8 bytes contain the ROM code
and CRC */
unsigned char rom_codes[MAX_DEVICES][9];
main()
unsigned char i,devices;
int temp;
/* initialize the UART's baud rate */
UBRR=xtal/16/baud-1;
/* initialize the UART control register
TX enabled, no interrupts, 8 data bits */
UCR=8;
/* detect how many DS1820/DS18S20 devices
are connected to the bus and
store their ROM codes in the rom_codes array */
devices=w1_search(0xf0,rom_codes);
/* display the number */
printf("%-u DEVICE(S) DETECTED\n\r",devices);
/* if no devices were detected then halt */
if (devices==0) while (1); /* loop forever */
/* measure and display the temperature(s) */
while (1)
for (i=0;i<devices;)
temp=ds1820_temperature_10(&rom_codes[0]);
printf("t%-u=%-i.%-u\xf8C\n\r",++i,temp/10,
abs(temp%10));
unsigned char ds1820_set_alarm(unsigned char *addr,signed char temp_low,signed char temp_high)
this function sets the low (temp_low) and high (temp_high) temperature alarms of the DS1820/DS18S20.
In case of success the function returns the value 1, else it returns 0.
The alarm temperatures are stored in both the DS1820/DS18S20's scratchpad SRAM and its EEPROM.
The ROM code needed to address the device is stored in an array of 8 bytes located at address addr.
The alarm status for all the DS1820/DS18S20 devices on the 1 Wire bus can be determined by calling the w1_search function with the Alarm Search (ECh) command.
Example:
#asm
.equ __w1_bit=2
#endasm
#include <ds1820.h>
#include <stdio.h>
#include <math.h>
/* Baud rate */
#define baud 9600
and CRC */
/* allocate space for ROM codes of the devices
which generate an alarm */
unsigned char alarm_rom_codes[MAX_DEVICES][9];
main()
int temp;
UCR=8;
/* set the temperature alarms for all the devices
temp_low=25癈 temp_high=35癈 */
for (i=0;i<devices;i++)
printf("INITIALIZING DEVICE #%-u ",i+1);
if (ds1820_set_alarm(&rom_codes[0],25,35))
putsf("OK"); else putsf("ERROR");
while (1)
abs(temp%10));
/* display the number of devices which
generated an alarm */
printf("ALARM GENERATED BY %-u DEVICE(S)\n\r",
w1_search(0xec,alarm_rom_codes));
Refer to the DS1820/DS18S20 data sheet for more information. |
