敬爱的马老师:
您好!我用AVR的SPI接口实现两片MEGA128通信的实验,在从机的LED数码管显示出来.我是想做一 个通信时钟,也就是在主机中编写时钟程序,通过SPI接口,在从机的6位数码管显示一个时钟.但SPI接口只有8位(一个字节),只能传输一个字节,双机通信我已经实现了一个LED位的传输.我的那个数码管是循环显示的,有4位,那么我该怎样让这四位显示分秒呢?在自发自收中我是实现出来了,但在双机通信中,却实现不了.因为在双机中,不可能让A口和C口的高四位(控制LED的)循环发送啊?
恳请马老师看看我的程序,并指点一下,谢谢马老师!!
1)主机程序:
#include <iom128v.h>
#include <macros.h>
#define SIZE 4
unsigned char time[2];
unsigned char dis_buff[4];//显示缓冲区,存放要显示的6个字符的段码值
unsigned char led_7[10]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
flash unsigned char position[4]={0xef,0xdf,0xbf,0x7f};
unsigned char SPI_rx_buffer[10]; //接收缓冲区
unsigned char time_counter=0;//1s计数器
unsigned char rx_wr_index,rx_rd_index,rx_counter,rx_buffer_overflow;
unsigned char k;
void port_init(void)
PORTA = 0x00;
DDRA = 0x00;
PORTB = 0x00;
DDRB = 0x00;
PORTC=0x00;
DDRC=0x00;
PORTD = 0x00;
DDRD = 0x00;
PORTE = 0x00;
DDRE = 0x00;
PORTF = 0x00;
DDRF = 0x00;
PORTG = 0x00;
DDRG = 0x00;
void delay_1ms(void)
{unsigned int i;
for(i=1;i<4*143-2;i++)
void delay(unsigned int n)
unsigned int i=0;
for(i=0;i<n;i++)
delay_1ms();
// clock rate: 57599hz
void spi_init(void)
char temp;
SPCR = 0xE3; //setup SPI,11100011
SPSR = 0x00; //setup SPI
temp=SPSR;
temp=SPDR;
//call this routine to initialize all peripherals
void init_devices(void)
//stop errant interrupts until set up
CLI(); //disable all interrupts
port_init();
spi_init();
MCUCR = 0x00;
EICRA = 0x00;
EICRB=0x00;
EIMSK=0x00;
EIFR=0x00;
TIMSK = 0x00; //timer interrupt sources
SEI(); //re-enable interrupts
//all peripherals are now initialized
#pragma interrupt_handler spi_stc_isr:18
void spi_stc_isr(void)
//byte in SPDR has been sent/received
SPI_rx_buffer[rx_wr_index]= SPDR;
if (++rx_wr_index == SIZE) rx_wr_index = 0; //放入接收缓冲区,并调整队列指针
if (++rx_counter == SIZE)
rx_counter = 0;
rx_buffer_overflow = 1;
unsigned char getSPIchar(data)
//unsigned char temp;
while(rx_counter==0)
//for(k=0;k<=3;k++)
data=SPI_rx_buffer[rx_rd_index];
//PORTA=data;
//PORTC=position[k];
// while(!(SPSR&1<<SPIF));
//PORTB|=(1<<PB0);
//SPSR = 0x00; //11010101
//temp = SPSR;//清空接收
//PORTA=SPDR;
//PORTB&=~(1<<PB0);
//delay(2);
//PORTC=0xff;}
if(++rx_rd_index==SIZE)rx_rd_index=0;
CLI();
--rx_counter;
SEI();
return data;
void time_to_disbuffer(void)//时间值送显示缓冲区函数
unsigned char i,j=0;
for(i=0;i<=1;i++)
dis_buff[j++]=time%10;
dis_buff[j++]=time/10;
{//PORTA = 0x00;
//DDRA = 0xff;
// PORTC=0x0f;
//DDRC=0xf0;
unsigned char j,temp;
CLI();
//spi_init();
//初始化SPI接口
init_devices();
PORTA=0Xff;
DDRA=0XFF;
PORTC=0Xff;
DDRC=0Xf0;
SEI();
DDRB|=(1<<PB3); //MIso 设置为输出
for(k=0;k<=3;k++)
{getSPIchar(j);//等待spi中断{};
PORTB|=(1<<PB0);
temp = SPSR;//清空接收
PORTA=j;
PORTB&=~(1<<PB0);
PORTC=position[k];
delay(2);
PORTC=0xff; //关闭所有的选通位
2)主机程序:
#include <macros.h>
#define SIZE 10
unsigned char SPI_tx_buff[SIZE];
unsigned char tx_wr_index,tx_rd_index,tx_counter;
unsigned char temp;
PORTA = 0x00;
DDRA = 0x00;
PORTB = 0x00;
DDRB = 0x00;
PORTC = 0x00;
DDRC = 0x00;
PORTD = 0xFF;
DDRD = 0xFF;
PORTE = 0x00;
DDRE = 0x00;
PORTF = 0x00;
DDRF = 0x00;
PORTG = 0x00;
DDRG = 0x00;
//SPI initialize
//clock rate: 6mhz
void spi_init(void)
PORTB |= (1<<PB0) | (1<<PB1) | (1<<PB2)|(1<<PB3) ;
DDRB |= (1<<DDB0) | (1<<DDB1) | (1<<DDB2); //Set MOSI, SCK AND SS as outputs
SPCR = 0x73; //setup SPI, 11110011
SPSR = 0x00; //setup SPI ,fosc/128
port_init();
spi_init();
MCUCR = 0x00;
EICRA = 0x00;
EICRB=0x00;
EIMSK=0x00;
EIFR=0x00;
{if(tx_counter)
--tx_counter;
SPDR=SPI_tx_buff[tx_rd_index];
if(++tx_rd_index==SIZE)tx_rd_index=0;
for(i=0;i<=1;i++)
void putSPIchar(char c)
{ unsigned char k;
PORTB &=~ (1<<PB0); //拉底ss,强制接收方进入从模式
SPCR |= (1<<MSTR); // MSTR有时会被清零,这里强制进入主机模式
//启动数据传输
for(k=0;k<=3;k++)
{c=led_7[dis_buff[k]];
while (tx_counter == SIZE);//发送缓冲区满,等待
CLI();
if (tx_counter || ((SPSR & 0x80) == 0))//发送缓冲区已中有待发数据
{ //或SPI正在发送数据时
SPI_tx_buff[tx_wr_index] = c; //将数据放入发送缓冲区排队
if(tx_counter)
--tx_counter;
if (++tx_wr_index == SIZE) tx_wr_index = 0; //调整指针
++tx_counter;
SPDR = c; //发送缓冲区中空且SPI口空闲,直接放入SPDR由SIP口发送
SEI();
//unsigned char k,cData;
{unsigned int i;
unsigned int i=0;
for(i=0;i<n;i++)
delay_1ms();
unsigned char i;
init_devices();
time[1]=56;time[0]=23;//时间初值为58:55
time_to_disbuffer();
putSPIchar(i);
i++;
if(++time_counter>=40)//显示扫描,执行时间为12ms
time_counter=0;
if(++time[0]>=60)
time[0]=0;
if(++time[1]>=60)
{ time[1]=0;
delay(17);//延时13ms,可进行其他处理
