发表于 2009-6-9 16:17:31
樓主精神可嘉,我支持你!
為了你的成功,我幫你找了一個合適的馬達。
Scorpion S-5545-150KV
[S-5545-150KV]
Click to enlarge Price: $299.99
Sorry, this product is currently out of stock and can not be ordered.
Scorpion Competition Series Brushless Motors are built from the best materials available, and are designed to provide both quality and performance at an affordable price. The new 55mm series motors have been designed to fit larger models that would normally require a 30cc to 50cc gasoline motor. Scorpion starts with high quality aluminum alloy parts that are produced on the latest CNC milling machines. These parts are then gold Electro-Plated to provide a beautiful, long-lasting finish. The stators are made with 0.2mm laminations to give maximum efficiency, and minimum Eddy current losses. The stators are epoxy coated to prevent shorts, and are wound with wire that is rated at 180 degrees C (356 F). The magnets used in Scorpion Motors are N-50EH style, which are rated for operation at 200 degrees C (392 F), making a motor that is virtually impossible to burn up in normal use.
All Scorpion 55mm motors come with 4.0mm male bullet style connectors already attached, and include a complete hardware package that contains the following: 3 matching female Bullet connectors for your speed controller, a cross style backplate mount with 4 screws, a thrust washer with tapered collar, a spacer collar that allow you to move the prop forward if needed, a heavy duty prop washer, a prop nut and two prop lock nuts that have threaded tips for use with a spinner.
Specifications
Stator Diameter 55mm (2.165 in)
Stator Thickness 45mm (1.772 in)
No. of Stator Arms 18
No. of Magnet Poles 20
Motor Wind 10 Turn Delta
Motor Wire 29-Strand 0.25mm
Motor Kv 150 RPM / Volt
No-Load Current (Io/10V) 1.31 Amps
Motor Resistance (Rm) 0.030 Ohms
Max Continuous Current 90 Amps
Max Continuous Power 3800 Watts
Weight 1025.9 Grams (34.69 oz)
Outside Diameter 65.4 mm (2.575 in)
Shaft Diameter 7.98 mm (0.314 in)
Body Length 89.25 mm (3.514 in)
Overall Shaft Length 137.25 mm (5.403 in)
Max Lipo Cell 12s
Weight including packaging
1320.4g |
