发表于 2007-4-25 11:53:21
以下是3个bug的具体内容:
[ 1684059 ] Makefile ASFLAGS parameters incorrect
You may monitor this Tracker item after you login (register an account, if you do not already have one)
Submitted By:
Nobody/Anonymous - nobody
Date Submitted:
2007-03-19 19:35
Last Updated By:
arcanum - Comment added
Date Last Updated:
2007-03-20 12:37
Number of Comments:
1
Number of Attachments:
0
Category: (?)
None
Group: (?)
None
Assigned To: (?)
Eric Weddington
Priority: (?)
5
Status: (?)
Open
Resolution: (?)
Fixed
Summary: (?)
Private: (?)
No
The following line in the Makefile template (WINAVR20070122) is incorrect:
ASFLAGS =
-Wa,-adhlns=$(<:.S=$(OBJDIR)/%.lst),-gstabs,--listing-cont-lines=100
A percentage sign is missing from the -adhlns parameter, causing incorrect
output to be omitted when a recompile is executed without being preceeded
by a make clean. The corrected line is:
ASFLAGS =
-Wa,-adhlns=$(<:%.S=$(OBJDIR)/%.lst),-gstabs,--listing-cont-lines=100
[ 1702167 ] Add ADEFS to makefile
Submitted By:
Date Submitted:
2007-04-17 05:10
Last Updated By:
Item Submitter - Tracker Item Submitted
Date Last Updated:
No updates since submission
Number of Comments:
0
0
Category: (?)
None
Group: (?)
None
Assigned To: (?)
Nobody/Anonymous
Priority: (?)
5
Status: (?)
Open
Resolution: (?)
None
Summary: (?)
Private: (?)
No
The current WinAVR Makefile template does not contain any facilities for
passing flags to the assembler. This means that F_CPU and such is not
avaliable to the assembler. Passing CDEFS is not enough, as the "UL" and
other similar C-only tokens are not accepted by the assembler.
Proposed solution is to add in a new "ADEFS" variable as pass it to the
assembler.
In the template, below CDEFS, add:
# Place -D or -U options here for ASM sources
ADEFS = -DF_CPU=$(F_CPU)
And change the line:
ASFLAGS =
Into:
ASFLAGS = $(ADEFS)
[ 1648575 ] "Device:" blank in output window
Submitted By:
sklerozzz - sklerozzz
Date Submitted:
2007-01-31 00:41
Last Updated By:
Date Last Updated:
2007-03-19 09:12
Number of Comments:
1
0
Category: (?)
None Group: (?)
None
Assigned To: (?)
Eric Weddington
Priority: (?)
5
Status: (?)
Open
Resolution: (?)
Accepted
Summary: (?)
Private: (?)
No
Device name is omitted in "AVR memory usage" section in output window.
To resolve, change line 427 of makefile_template from
ELFSIZE = $(SIZE) --format=avr $(TARGET).elf
to
ELFSIZE = $(SIZE) --mcu=$(MCU)--format=avr $(TARGET).elf
-----此内容被yyccaa于2007-04-25,11:54:12编辑过 |
