先上视频http://v.youku.com/v_show/id_XMTI1OTQ2MzU2MA==.html
电路图
现在问题是噪音巨大而且电流也很大,似乎有许多换相是错误的。我把我的代码贴上来希望大神能够帮忙看一眼哪里有错误
整体算法是下桥PWM,PWM低电平同步比较器采样,换相后7.5度开始检测过零,过零后15度执行换相(0-30度都试过,不好使)
下面是自动换向器模块的代码
- module auto_commutator_sydelay(ac_clk,ac_en,ac_rst,ac_01a,ac_01b,ac_01c,ac_10a,ac_10b,ac_10c,ac_phase
- input ac_clk,ac_en,ac_rst,ac_01a,ac_01b,ac_01c,ac_10a,ac_10b,ac_10c;//输入的信号来自过零检测模块,分别代表a,b,c比较器输出发生0->1或者1->0的变化
- output[3:0] ac_phase;
- reg[3:0] ac_phase;
- reg count_flag;
- reg[23:0] count;
- reg[23:0] demag_count;
- wire count_zero;
- assign count_zero=(count<11);
- parameter[3:0]
- P_0=0,
- P_1=1,
- P_2=2,
- P_3=3,
- P_4=4,
- P_5=5,
- P_6=6,
- P_1d=7,
- P_2d=8,
- P_3d=9,
- P_4d=10,
- P_5d=11,
- P_6d=12;
- reg [15:0]state,next_state;
- always @(ac_01b or ac_01c or ac_10a or ac_10b or ac_10c or ac_en or count_zero)//@(ac_a or ac_b or ac_c or ac_en or count_zero)\\检测到过零事件或者等待换相事件到达
- begin
- next_state=16'b0;
- case(1'b1)
- state[P_0]:begin
- if(ac_en)
- begin
- next_state[P_1]=1'b1;
- ac_phase=1;
- // count_flag=0;
- end
- else
- begin
- next_state[P_0]=1'b1;
- ac_phase=0;
- end
- end
- state[P_1]:begin
- if((ac_01c==1)&&(count>demag_count))\\当比较器发生跳变且距离上一次换相已经大于7.5电角度时过零事件有效(利用7.5电角度来屏蔽消磁)
- begin
- next_state[P_1d]=1'b1;
- demag_count<=(count>>2);
- ac_phase=1;
- end
- else
- begin
- ac_phase=1;
- end
- end
- state[P_1d]:begin//过零后等待等待时间到达,执行换相,这里等待的是15电角度(其他值也是不好),很奇怪。
- if(count_zero)
- begin
- next_state[P_2]=1'b1;
- ac_phase=2;
- end
- else
- begin
- ac_phase=1;
- end
- end
- state[P_2]:begin
- if((ac_10b==1)&&(count>demag_count))
- begin
- next_state[P_2d]=1'b1;
- ac_phase=2;
- end
- else
- begin
- ac_phase=2;
- end
- end
- state[P_2d]:begin
- if(count_zero)
- begin
- next_state[P_3]=1'b1;
- ac_phase=3;
- end
- else
- begin
- ac_phase=2;
- end
- end
- state[P_3]:begin
- if((ac_01a==1)&&(count>demag_count))
- begin
- next_state[P_3d]=1'b1;
- ac_phase=3;
- end
- else
- begin
- ac_phase=3;
- end
- end
- state[P_3d]:begin
- if(count_zero)
- begin
- next_state[P_4]=1'b1;
- ac_phase=4;
- end
- else
- begin
- ac_phase=3;
- end
- end
- state[P_4]:begin
- if((ac_10c==1)&&(count>demag_count))
- begin
- next_state[P_4d]=1'b1;
- ac_phase=4;
- end
- else
- begin
- ac_phase=4;
- end
- end
- state[P_4d]:begin
- if(count_zero)
- begin
- next_state[P_5]=1'b1;
- ac_phase=5;
- end
- else
- begin
- ac_phase=4;
- end
- end
- state[P_5]:begin
- if((ac_01b==1)&&(count>demag_count))
- begin
- next_state[P_5d]=1'b1;
- ac_phase=5;
- end
- else
- begin
- ac_phase=5;
- end
- end
- state[P_5d]:begin
- if(count_zero)
- begin
- next_state[P_6]=1'b1;
- ac_phase=6;
- end
- else
- begin
- ac_phase=5;
- end
- end
- state[P_6]:begin
- if((ac_10a==1)&&(count>demag_count))
- begin
- next_state[P_6d]=1'b1;
- ac_phase=6;
- end
- else
- begin
- ac_phase=6;
- end
- end
- state[P_6d]:begin
- if(count_zero)
- begin
- ac_phase=1;
- end
- else
- begin
- ac_phase=6;
- end
- end
- default:begin
- ac_phase=0;
- end
- endcase
- end
- always @(negedge ac_rst or posedge ac_clk)
- begin
- if (!ac_rst)
- begin
- state <= (1'b1 << P_0) ;
- count<=0;
- end
- else
- begin
- state <=(next_state) ;
- if((state[P_1]==1)||(state[P_2]==1)||(state[P_3]==1)||(state[P_4]==1)||(state[P_5]==1)||(state[P_6]==1))//计算一个从换相到下一次过零的时间用于过零后到下一次换相的延时
- begin
- count<=count+1;
- end
- else if((state[P_1d]==1)||(state[P_2d]==1)||(state[P_3d]==1)||(state[P_4d]==1)||(state[P_5d]==1)||(state[P_6d]==1)) //计算一个从换相到下一次过零的时间用于过零后到下一次换相的延时
- begin
- count<=count-2;
- end
- end
- end
- endmodule
过零探测模块
- module zero_detector(zd_clk,zd_rst,zd_in,zd_sync,zd_01out,zd_10out
- input zd_clk,zd_rst,zd_in,zd_sync;
- output zd_01out;
- wire zd_01out;
- output zd_10out;
- wire zd_10out;
- reg[1:0] zd_state_now;
- reg c_state;
- reg[3:0] filter_buf;
- assign zd_10out=zd_state_now[1]&(!zd_state_now[0]);
- assign zd_01out=zd_state_now[0]&(!zd_state_now[1]);//zd_state_now[1]^zd_state_now[0];
- always @(posedge zd_clk,negedge zd_rst)
- begin
- zd_state_now<={zd_state_now[0],c_state};
- if(!zd_rst)
- begin
- zd_state_now<=0;
- end
- else
- begin
- if(filter_buf[1:0]==0)
- begin
- c_state<=0;
- end
- else if(filter_buf[1:0]==3)//检测到两个0或两个1的读数则认为此时读数为0或1
- begin
- c_state<=1;
- end
- end
- end
- always @(posedge zd_sync)
- begin
- filter_buf<={filter_buf[2:0],zd_in};//同步的采样。每次在PWM为低电平即将翻转成高电平之前会到来zd_sync
- end
- endmodule
驱动桥模块,下桥PWM
- module bridge_driver(bridge_rst,bridge_clk,bridge_pwm_in,a_up,b_up,c_up,bridge_ah,bridge_al,bridge_bh,bridge_bl,bridge_ch,bridge_cl,bridge_phase
- input bridge_rst,bridge_clk,bridge_pwm_in,a_up,b_up,c_up;
- input[3:0] bridge_phase;
- output bridge_ah,bridge_al,bridge_bh,bridge_bl,bridge_ch,bridge_cl;
- reg bridge_ah,bridge_al,bridge_bh,bridge_bl,bridge_ch,bridge_cl;
- always @ (posedge bridge_clk or negedge bridge_rst)
- begin
- if(!bridge_rst)
- begin
- bridge_ah<=1;
- bridge_al<=0;
- bridge_bh<=1;
- bridge_bl<=0;
- bridge_ch<=1;
- bridge_cl<=0;
- end
- else
- begin
- case(bridge_phase)
- 0:begin
- bridge_ah<=1;
- bridge_al<=0;
- bridge_bh<=1;
- bridge_bl<=0;
- bridge_ch<=1;
- bridge_cl<=0;
- end
- 1:begin
- bridge_ah<=0;//(!((!a_up)|bridge_pwm_in));
- bridge_al<=0;
- bridge_bh<=1;
- bridge_bl<=((b_up)|bridge_pwm_in);
- bridge_ch<=1;
- bridge_cl<=0;
- end
- 2:begin
- bridge_al<=0;
- bridge_bh<=1;
- bridge_bl<=0;
- bridge_ch<=1;
- bridge_cl<=((c_up)|bridge_pwm_in);
- end
- 3:begin
- bridge_ah<=1;
- bridge_al<=0;
- bridge_bh<=0;//(!((!b_up)|bridge_pwm_in));
- bridge_bl<=0;
- bridge_ch<=1;
- end
- 4:begin
- bridge_ah<=1;
- bridge_al<=((a_up)|bridge_pwm_in);
- bridge_bl<=0;
- bridge_ch<=1;
- bridge_cl<=0;
- end
- 5:begin
- bridge_ah<=1;
- bridge_bh<=1;
- bridge_bl<=0;
- bridge_ch<=0;//(!((!c_up)|bridge_pwm_in));
- bridge_cl<=0;
- end
- 6:begin
- bridge_ah<=1;
- bridge_al<=0;
- bridge_bh<=1;
- bridge_cl<=0;
- end
- 7:begin
- bridge_ah<=!bridge_pwm_in;
- bridge_al<=0;
- bridge_bh<=1;
- bridge_bl<=1;
- bridge_ch<=1;
- bridge_cl<=1;
- end
- endcase
- end
- end
- endmodule
复制代码 |
