发表于 2014-10-30 13:42:17
我的不会呀,就是错位,我发我的代码给你看看!#include "mcu_spi.h"
#include "stdio.h"
#define sFLASH_CS_LOW() GPIO_ResetBits(GPIOA, GPIO_Pin_2)
#define sFLASH_CS_HIGH() GPIO_SetBits(GPIOA, GPIO_Pin_2)
#define sFLASH_CMD_WRSR 0x01
#define sFLASH_CMD_WRITE 0x02
#define sFLASH_CMD_READ 0x03
#define sFLASH_CMD_DISWR 0x04
#define sFLASH_CMD_RDSR 0X05
#define sFLASH_CMD_ENWR 0x06
#define sFLASH_DUMMY_BYTE 0xFF
#define sFLASH_CMD_BE 0xc7
#define sFLASH_CMD_SE 0xd8
#define sFLASH_CMD_RDID 0x9f
#define sFLASH_IDADDR 0x14
#define sFLASH_SPI_PAGESIZE 0x100 //one page 256 byte
#define sFLASH_W25X16_ID 0x3015
u8 Rvcbuf2[10];
u8 Sendbuf2[10]= {
0x01,0x02,0x03,0x04,
0x05,0x06,0x07,0x08,
0x09,0x0a
#define SPI_MASTER_DR_Base 0x4001300C
DMA_InitTypeDef DMA_InitStructure;
void SPI1_Init(void)
SPI_InitTypeDef SPI_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|
RCC_APB2Periph_GPIOB|RCC_APB2Periph_AFIO|\
RCC_APB2Periph_SPI1, ENABLE);
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_7;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA , &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(GPIOA, &GPIO_InitStructure);
//spi enable pin
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
DMA_DeInit(DMA1_Channel2);
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)SPI_MASTER_DR_Base;
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)Rvcbuf2;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
DMA_InitStructure.DMA_BufferSize = 0xffff;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel2, &DMA_InitStructure);
DMA_DeInit(DMA1_Channel3);
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)Sendbuf2;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
DMA_InitStructure.DMA_Priority = DMA_Priority_Low;
DMA_Init(DMA1_Channel3, &DMA_InitStructure);
SPI_Cmd(SPI1, DISABLE);
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPI1, &SPI_InitStructure);
SPI_Cmd(SPI1, ENABLE);
SPI_I2S_DMACmd(SPI1, SPI_I2S_DMAReq_Tx, ENABLE);
SPI_I2S_DMACmd(SPI1, SPI_I2S_DMAReq_Rx, ENABLE);
NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel3_IRQn;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
DMA_ITConfig(DMA1_Channel2,DMA_IT_TC,ENABLE);
DMA_ITConfig(DMA1_Channel3,DMA_IT_TC,ENABLE);
DMA_Cmd(DMA1_Channel2, DISABLE);
DMA_Cmd(DMA1_Channel3, DISABLE);
u8 sFLASH_SendByte(u8 dat)
while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
SPI_I2S_SendData(SPI1,dat);
while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);
return SPI_I2S_ReceiveData(SPI1);
void sFLASH_WriteEnable(void)
sFLASH_CS_LOW();
sFLASH_SendByte(sFLASH_CMD_ENWR);
sFLASH_CS_HIGH();
void sFLASH_WaitForWriteEnd(void)
uint8_t flashstatus = 0;
sFLASH_CS_LOW();
sFLASH_SendByte(sFLASH_CMD_RDSR);
do
flashstatus = sFLASH_SendByte(sFLASH_DUMMY_BYTE);
while ((flashstatus & 0x01) == SET);
sFLASH_CS_HIGH();
void Flash_WritePage(uint8_t* pBuffer, u32 WriteAddr, uint16_t NumByteToWrite)
sFLASH_WriteEnable();
sFLASH_WaitForWriteEnd();
sFLASH_CS_LOW();
sFLASH_SendByte(sFLASH_CMD_WRITE);
sFLASH_SendByte((WriteAddr&0xFF0000)>>16);
sFLASH_SendByte((WriteAddr&0xFF00)>>8);
sFLASH_SendByte(WriteAddr&0xFF);
//hard mode write
// if(NumByteToWrite>256)
// NumByteToWrite=256;
// while(NumByteToWrite--)
// sFLASH_SendByte(*pBuffer);
// pBuffer++;
//DMA mode write
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)pBuffer;
DMA_InitStructure.DMA_BufferSize = NumByteToWrite;
DMA_Cmd(DMA1_Channel3,ENABLE);
u8 sFLASH_ReadByte(void)
return (sFLASH_SendByte(sFLASH_DUMMY_BYTE));
//hard mode read
void sFLASH_ReadBuffer(uint8_t* pBuffer, uint16_t ReadAddr, uint16_t NumByteToRead)
sFLASH_CS_LOW();
sFLASH_SendByte(sFLASH_CMD_READ);
sFLASH_SendByte((ReadAddr & 0xFF0000) >> 16);
sFLASH_SendByte((ReadAddr& 0xFF00) >> 8);
sFLASH_SendByte(ReadAddr & 0xFF);
while (NumByteToRead--)
*pBuffer++ = sFLASH_ReadByte();
void sFLASH_BulkErase(void)
sFLASH_CS_LOW();
sFLASH_SendByte(sFLASH_CMD_BE);
sFLASH_CS_HIGH();
void DMA1_Channel2_IRQHandler(void)
if(DMA_GetFlagStatus(DMA1_IT_TC2) != RESET)
DMA_ClearFlag(DMA1_IT_GL2);
DMA_Cmd(DMA1_Channel2, DISABLE); }
void DMA1_Channel3_IRQHandler(void)
if(DMA_GetFlagStatus(DMA1_IT_TC3) != RESET)
DMA_ClearFlag(DMA1_IT_GL3);
void SPI_Flash_Check(void)
Flash_WritePage((u8*)&Sendbuf2,0,10);
delay_ms(10);
sFLASH_CS_HIGH();
sFLASH_ReadBuffer((u8*)&Rvcbuf2,0,10);
delay_ms(100);
LED_RED_FLASH();
printf("Rvcbuf2[0]=: %x\n\n\n\n\n",Rvcbuf2[0]);
printf("Rvcbuf2[1]=: %x\n\n\n\n\n",Rvcbuf2[1]);
printf("Rvcbuf2[2]=: %x\n\n\n\n\n",Rvcbuf2[2]);
printf("Rvcbuf2[3]=: %x\n\n\n\n\n",Rvcbuf2[3]);
printf("Rvcbuf2[4]=: %x\n\n\n\n\n",Rvcbuf2[4]);
printf("Rvcbuf2[5]=: %x\n\n\n\n\n",Rvcbuf2[5]);
printf("Rvcbuf2[6]=: %x\n\n\n\n\n",Rvcbuf2[6]);
printf("Rvcbuf2[7]=: %x\n\n\n\n\n",Rvcbuf2[7]);
printf("Rvcbuf2[8]=: %x\n\n\n\n\n",Rvcbuf2[8]);
printf("Rvcbuf2[9]=: %x\n\n\n\n\n",Rvcbuf2[9]);
打印信息:
rvc[0] =0xff
rvc[1] =0x01
rvc[2] =0x02
rvc[3] =0x03
rvc[4] =0x04
rvc[5] =0x05
rvc[6] =0x06
rvc[7] =0x07
rvc[8] =0x08
rvc[9] =0x0a
切换回硬件,不用DMA就正常了!
