using System.Runtime.InteropServices;
using System.Threading;
using System;
internal class JTAG
public void JLINKARM_Sleep(int ms)
Thread.Sleep(ms);
/// <summary>
/// 打开JLINK设备
/// </summary>
/// <remarks></remarks>
[DllImport("JLinkARM.dll", CharSet = CharSet.Ansi, SetLastError = true, ExactSpelling = true)]
public void JLINKARM_Open()
/// <summary>
/// 关闭JLINK设备
/// </summary>
public void JLINKARM_Close()
/// <summary>
/// 系统复位
/// </summary>
public void JLINKARM_Reset()
public void JLINKARM_GoAllowSim()
/// <summary>
/// 执行程序
/// </summary>
public void JLINKARM_Go()
/// <summary>
/// 中断程序执行
/// </summary>
/// <returns></returns>
public bool JLINKARM_Halt()
/// <summary>
/// 单步执行
/// </summary>
public bool JLINKARM_Step()
/// <summary>
/// 清除错误信息
/// </summary>
public void JLINKARM_ClrError()
/// <summary>
/// 设置JLINK接口速度
/// </summary>
/// <param name="speed"></param>
/// <remarks>0为自动调整</remarks>
public void JLINKARM_SetSpeed(int speed)
/// <summary>
/// 设置JTAG为最高速度
/// </summary>
public void JLINKARM_SetMaxSpeed()
public UInt16 JLINKARM_GetSpeed()
public UInt32 JLINKARM_GetVoltage()
/// <summary>
/// 当前MCU是否处于停止状态
/// </summary>
public bool JLINKARM_IsHalted()
public bool JLINKARM_IsConnected()
/// <summary>
/// JLINK是否已经可以操作了
/// </summary>
public bool JLINKARM_IsOpen()
/// <summary>
/// 取消程序断点
/// </summary>
/// <param name="index">断点序号</param>
/// <remarks>配合JLINKARM_SetBP()使用</remarks>
public void JLINKARM_ClrBP(UInt32 index)
/// <summary>
/// 设置程序断点
/// </summary>
/// <param name="addr">目标地址</param>
/// <remarks>建议使用JLINKARM_SetBPEx()替代</remarks>
public void JLINKARM_SetBP(UInt32 index, UInt32 addr)
/// <summary>
/// 设置程序断点
/// </summary>
/// <param name="mode">断点类型</param>
/// <returns>Handle,提供给JLINKARM_ClrBPEx()使用</returns>
public int JLINKARM_SetBPEx(UInt32 addr, BP_MODE mode)
/// <summary>
/// 取消程序断点
/// </summary>
/// <param name="handle"></param>
/// <remarks>配合JLINKARM_SetBPEx()使用</remarks>
public void JLINKARM_ClrBPEx(int handle)
private int JLINKARM_SetWP(UInt32 addr, UInt32 addrmark, UInt32 dat, UInt32 datmark, byte ctrl, byte ctrlmark)
/// <summary>
/// 取消数据断点
/// </summary>
/// <remarks>配合JLINKARM_SetWP()使用</remarks>
public void JLINKARM_ClrWP(int handle)
/// <summary>
/// 设置寄存器
/// </summary>
/// <param name="index"></param>
/// <param name="dat"></param>
public void JLINKARM_WriteReg(ARM_REG index, UInt32 dat)
/// <summary>
/// 读取寄存器
/// </summary>
public UInt32 JLINKARM_ReadReg(ARM_REG index)
/// <summary>
/// 写入一段数据
/// </summary>
/// <param name="addr"></param>
/// <param name="size"></param>
/// <param name="buf"></param>
public void JLINKARM_WriteMem(UInt32 addr, UInt32 size, byte[] buf)
/// <summary>
/// 读取一段数据
/// </summary>
public void JLINKARM_ReadMem(UInt32 addr, UInt32 size, [Out(), MarshalAs(UnmanagedType.LPArray)] byte[] buf)
/// <summary>
/// 从调试通道获取一串数据
/// </summary>
/// <param name="size">需要获取的数据长度</param>
public void JLINKARM_ReadDCCFast([Out(), MarshalAs(UnmanagedType.LPArray)] UInt32[] buf, UInt32 size)
/// <summary>
/// 从调试通道获取一串数据
/// </summary>
/// <param name="size">希望获取的数据长度</param>
/// <param name="timeout"></param>
/// <returns>实际获取的数据长度</returns>
public UInt32 JLINKARM_ReadDCC([Out(), MarshalAs(UnmanagedType.LPArray)] UInt32[] buf, UInt32 size, int timeout)
/// <summary>
/// 向调试通道写入一串数据
/// </summary>
/// <param name="size">需要写入的数据长度</param>
public void JLINKARM_WriteDCCFast(UInt32[] buf, UInt32 size)
/// <summary>
/// 向调试通道写入一串数据
/// </summary>
/// <param name="size">希望写入的数据长度</param>
/// <returns>实际写入的数据长度</returns>
public UInt32 JLINKARM_WriteDCC(UInt32[] buf, UInt32 size, int timeout)
/// <summary>
/// 获取JLINK的DLL版本号
/// </summary>
/// <remarks>使用10进制数表示</remarks>
public UInt32 JLINKARM_GetDLLVersion()
/// <summary>
/// 获取JLINK的固件版本号
/// </summary>
public UInt32 JLINKARM_GetHardwareVersion()
private void JLINKARM_GetFeatureString( [Out(), MarshalAs(UnmanagedType.LPArray)] byte[] oBuffer)
private void JLINKARM_GetOEMString( [Out(), MarshalAs(UnmanagedType.LPArray)] byte[] oBuffer)
public Text.StringBuilder JLINKARM_GetCompileDateTime()
public UInt32 JLINKARM_GetSN()
/// <summary>
/// 获取当前MCU的ID号
/// </summary>
public UInt32 JLINKARM_GetId()
private void JLINKARM_ReadMemU32(UInt32 addr, UInt32 leng, ref UInt32 buf, ref byte status)
/// <summary>
/// 写入32位的数据
/// </summary>
public void JLINKARM_WriteU32(UInt32 addr, UInt32 dat)
private void JLINKARM_ReadMemU16(UInt32 addr, UInt32 leng, ref UInt16 buf, ref byte status)
/// <summary>
/// 写入16位的数据
/// </summary>
public void JLINKARM_WriteU16(UInt32 addr, UInt16 dat)
private void JLINKARM_ReadMemU8(UInt32 addr, UInt32 leng, ref byte buf, ref byte status)
/// <summary>
/// 写入8位的数据
/// </summary>
public void JLINKARM_WriteU8(UInt32 addr, byte dat)
/// <summary>
/// 读取32位的数据
/// </summary>
public UInt32 JLINKARM_ReadU32(UInt32 addr)
UInt32 dat;
byte stu;
JLINKARM_ReadMemU32(addr, 1, dat, stu);
return dat;
/// <summary>
/// 读取16位的数据
/// </summary>
public UInt16 JLINKARM_ReadU16(UInt32 addr)
UInt16 dat;
byte stu;
JLINKARM_ReadMemU16(addr, 1, dat, stu);
return dat;
/// <summary>
/// 读取8位的数据
/// </summary>
public byte JLINKARM_ReadU8(UInt32 addr)
byte dat;
byte stu;
JLINKARM_ReadMemU8(addr, 1, dat, stu);
return dat;
/// <summary>
/// 设置数据断点
/// </summary>
/// <param name="addrmark">地址屏蔽位</param>
/// <param name="dat">目标数据</param>
/// <param name="datmark">数据屏蔽位</param>
/// <param name="mode">触发模式</param>
/// <returns>Handle,提供给JLINKARM_ClrWP()函数使用</returns>
/// <remarks>当前数值除了屏蔽位以外的数据位,与目标数据除了屏蔽位以外的数据位,一致即可产生触发</remarks>
public int JLINKARM_SetWP(UInt32 addr, UInt32 addrmark, UInt32 dat, UInt32 datmark, WP_MODE mode)
switch (mode) {
case WP_MODE.READ_WRITE:
return JLINKARM_SetWP(addr, addrmark, dat, datmark, 0x8, 0xf7);
case WP_MODE.READ:
return JLINKARM_SetWP(addr, addrmark, dat, datmark, 0x8, 0xf6);
case WP_MODE.WRITE:
return JLINKARM_SetWP(addr, addrmark, dat, datmark, 0x9, 0xf6);
public string JLINKARM_StringFeature()
byte[] aa = new byte[1000];
JLINKARM_GetFeatureString(aa);
Text.ASCIIEncoding kk = new Text.ASCIIEncoding();
string ss = kk.GetString(aa);
return ss;
public string JLINKARM_StringOEM()
JLINKARM_GetOEMString(aa);
return ss;
public void JLINKARM_Setup(string cmdstr)
//RmAnnotate rm = new RmAnnotate();
//rm.MarkDosMode = false;
//rm.MarkStartSpaceToTab = 0;
//cmdstr = rm.Convert(cmdstr);
cmdstr = cmdstr.Replace(' ', "");
cmdstr = cmdstr.Replace(vbLf, "");
cmdstr = cmdstr.Replace(vbTab, "");
string[] cmd = cmdstr.Split(';');
for (int i = 0; i <= cmd.Length - 1; i++) {
_setupDoCmd(cmd(i));
private void _setupDoCmd(string cmdstr)
string cmd = cmdstr.ToLower();
cmd = cmd.Replace("(", ",");
cmd = cmd.Replace(")", "");
cmd = cmd.TrimEnd(',');
string[] arg = cmd.Split(',');
UInt32 val1;
UInt32 val2;
if (arg.Length == 3) {
cmd = arg(0);
val1 = _setupGetVal(arg(1));
val2 = _setupGetVal(arg(2));
} else if (arg.Length == 2) {
cmd = arg(0);
val2 = 0;
} else if (arg.Length == 1) {
cmd = arg(0);
val1 = 0;
val2 = 0;
} else {
cmd = "";
val1 = 0;
val2 = 0;
if (cmd != "") {
Debug.WriteLine("Do CMD: " + cmdstr);
switch (cmd) {
case "SetJTAGSpeed".ToLower:
JTAG.JLINKARM_SetSpeed(val1);
case "Delay".ToLower:
JTAG.JLINKARM_Sleep(val1);
case "DisableMMU".ToLower:
Debug.WriteLine("...........................CMD not Supported");
case "Go".ToLower:
JTAG.JLINKARM_Go();
case "Halt".ToLower:
JTAG.JLINKARM_Halt();
case "Reset".ToLower:
JTAG.JLINKARM_Reset();
if (val1) {
case "ResetBP0".ToLower:
case "ResetADI".ToLower:
case "Read8".ToLower:
JTAG.JLINKARM_ReadU8(val1);
case "Read16".ToLower:
JTAG.JLINKARM_ReadU16(val1);
case "Read32".ToLower:
JTAG.JLINKARM_ReadU32(val1);
case "Verify8".ToLower:
do {
byte aa = JTAG.JLINKARM_ReadU8(val1);
if (aa == (byte)val2 & 0xff) {
break; // TODO: might not be correct. Was : Exit Do
JTAG.JLINKARM_Sleep(1);
} while (true);
case "Verify16".ToLower:
do {
ushort aa = JTAG.JLINKARM_ReadU16(val1);
if (aa == (ushort)val2 & 0xffff) {
} while (true);
case "Verify32".ToLower:
do {
uint aa = JTAG.JLINKARM_ReadU32(val1);
if (aa == val2) {
} while (true);
case "Write8".ToLower:
JTAG.JLINKARM_WriteU8(val1, val2);
case "Write16".ToLower:
JTAG.JLINKARM_WriteU16(val1, val2);
case "Write32".ToLower:
JTAG.JLINKARM_WriteU32(val1, val2);
case "WriteVerify8".ToLower:
do {
} while (true);
case "WriteVerify16".ToLower:
do {
} while (true);
case "WriteVerify32".ToLower:
do {
if (aa == val2) {
} while (true);
case "WriteRegister".ToLower:
JTAG.JLINKARM_WriteReg(val1, val2);
case "WriteJTAG_IR".ToLower:
case "WriteJTAG_DR".ToLower:
default:
Debug.WriteLine("...........................Unkonwned CMD");
private UInt32 _setupGetVal(string str)
UInt32 dd;
if (str.StartsWith("0x") && str.Length >= 3) {
dd = Convert.ToUInt32(str.Substring(2), 16);
} else {
dd = Convert.ToUInt32(str);
return dd;
/// <summary>
/// ARM内部寄存器
/// </summary>
public enum ARM_REG : UInt32
R0,
R1,
R2,
R3,
R4,
R5,
R6,
R7,
CPSR,
R15,
R8_USR,
R9_USR,
R10_USR,
R11_USR,
R12_USR,
R13_USR,
R14_USR,
SPSR_FIQ,
R8_FIQ,
R9_FIQ,
R10_FIQ,
R11_FIQ,
R12_FIQ,
R13_FIQ,
R14_FIQ,
SPSR_SVC,
R13_SVC,
R14_SVC,
SPSR_ABT,
R13_ABT,
R14_ABT,
SPSR_IRQ,
R13_IRQ,
R14_IRQ,
SPSR_UND,
R13_UND,
R14_UND,
SPSR_SYS,
R13_SYS,
R14_SYS,
PC = 9
/// <summary>
/// 程序断点模式
/// </summary>
public enum BP_MODE : UInt32
ARM = 1,
THUMB = 2,
HARD_ARM = 0xffffff01u,
HARD_THUMB = 0xffffff02u,
SOFT_ARM = 0xf1u,
SOFT_THUMB = 0xf2u
/// <summary>
/// 数据断点模式
/// </summary>
public enum WP_MODE : UInt32
READ_WRITE,
READ,
WRITE
