很快的 Keil 又再次的将之前 MDK 4.73 更新版本到 v4.74 了。喜新厌旧的请尽速啦!附上的连结有其时效性!同样的逾时不候呦!~
连结在此 -> MDK474.EXE
What's New in MDKARM Version 4.74
.[µVision]
.This MDK-ARM release is delivered with µVision V4.74.0.22 IDE.
.[ARM Middleware]
.Corrected: the FAT file name processing in FlashFS (filenames with leading '.' were not listed). The library version 4.74 includes the corrected FTP server interface module.
.Corrected: overlap bug in fcheck() function for EFS.
.[Device Simulation]
.Added: parameter -MULS to the Cortex-M0 simulator, which configures Multiplier Implementation type as "Small"(32-cycle iterative multiplier).
.Corrected: behaviour of simulation when executing DCW instruction.
.[Target debugging]
.Updated: Segger J-Link driver for ARM devices to version 4.76d.
.Updated: J-Link USB Driver Installer to support CDC.
.Updated: support for ST-Link USB-JTAG debugger. The ST-LINKIII-KEIL_SWO.dll MDK driver in folder ..\ARM\STLink\ has been updated to version 2.0.5.0.
.[CMSIS]
.Updated to CMSIS 4.0 including:
.CMSIS-CORE 3.30 (updated).
.CMSIS-DSP 1.4.2 (updated).
.CMSIS-RTOS-API 1.02.
.CMSIS-SVD 1.1.
.[Board Support]
.NXP Semiconductors
.Added: Blinky and RTX_Blinky examples for MCB1500 starter kit, based on LPC1549 device.
.[New Supported Devices]
.Atmel
SAMG51G18, SAMG51N18, SAMG53G19, SAMG53N19,
SAM4CP16B, SAM4CMP16C CM4P0, SAM4CMP16C CM4P1, SAM4CMP8C CM4P0, SAM4CMP8C CM4P1,
SAM4CMS16C CM4P0, SAM4CMS16C CM4P1, SAM4CMS8C CM4P0, SAM4CMS8C CM4P1,
SAMD21E15A, SAMD21E16A, SAMD21E17A, SAMD21E18A,
SAMD21G16A, SAMD21G17A, SAMD21G18A,
SAMD21J16A, SAMD21J18A, SAMD21J16A,
SAMR21E16A, SAMR21E17A, SAMR21E18A,
SAMR21G16A, SAMR21G17A, and SAMR21G18A.
.Cypress
CY8C4013SXI-411, CY8C4013LQI-411, CY8C4013SXI-400, CY8C4013SXI-410,
CY8C4014LQI-421, CY8C4014LQI-412, CY8C4014SXI-411, CY8C4014SXI-421,
CY8C4014LQI-422, CY8C4014LQI-SLT1, and CY8C4014LQI-SLT2.
.Freescale Semiconductor
SKEAZ128xxx4, SKEAZ64xxx4, SKEAZN8xxx4, SKEAZN16xxx2, SKEAZN32xxx2, SKEAZN64xxx2,
MKE04Z8xxx4, MKE02Z16xxx2, MKE02Z32xxx2, and MKE02Z64xxx2.
.NXP
LPC1517, LPC1518, LPC1519, LPC1547, LPC1548, and LPC1549.
.Spansion
S6E1A11B0A, S6E1A11C0A, S6E1A12B0A, and S6E1A12C0A.
.STMicroelectronics
STM32F401CD, STM32F401RD, STM32F401VD, STM32F401CE, STM32F401RE, STM32F401VE, and
STM32L162RD.
.Texas Instruments
TM4C123GH6ZXR, TM4C1290NCPDT, TM4C1290NCZAD, TM4C1292NCPDT, TM4C1292NCZAD,
TM4C1294KCPDT, TM4C1294NCPDT, TM4C1294NCZAD, TM4C1299KCZAD, TM4C129CNCPDT, TM4C129CNCZAD,
TM4C129DNCPDT, TM4C129DNCZAD, TM4C129EKCPDT, TM4C129ENCPDT, TM4C129ENCZAD, and TM4C129XNCZAD.
