在linux或android系统中,假如我们要配置飞思卡尔IMX6处理器的GPIO管脚,比如是GPIO_19这个管脚,那么要像这样:
#define MX6Q_PAD_GPIO_19__GPIO_4_5 \
(_MX6Q_PAD_GPIO_19__GPIO_4_5| MUX_PAD_CTRL(NO_PAD_CTRL))
其中_MX6Q_PAD_GPIO_19__GPIO_4_5定义为:
#define _MX6Q_PAD_GPIO_19__GPIO_4_5 \
IOMUX_PAD(0x0624, 0x0254, 5, 0x0000, 0, 0)
这个IOMUX_PAD宏是定义GPIO的关键宏,其原型为:
#define IOMUX_PAD(_pad_ctrl_ofs, _mux_ctrl_ofs, _mux_mode, _sel_input_ofs,
_sel_input, _pad_ctrl)
IOMUX_PAD宏有6个参数,每个参数的意思是:
_pad_ctrl_ofs 控制寄存器的偏移地址(16进制)
_mux_ctrl_ofs MUX控制寄存器的偏移地址(16进制), 用于选择引脚的功能
_mux_mode MUX模式,bit0~3,范围0~7
_select_input_ofs SELECT_INPUT寄存器偏移地址(16进制)
_select_input Daisy Chain模式, bit0~1,范围0~3
_pad_ctrl bits to be set in register _pad_ctrl_ofs for configuration selection
具体的含义要结合IMX6数据手册【Chapter 36 IMOUX Controller(IOMUXC)】的内容。
以下就GPIO_19这个管脚的配置进行说明:
1、_pad_ctrl_ofs
找到数据手册:
从上图可知:_pad_ctrl_ofs = 0x624
2、_mux_ctrl_ofs、_mux_mode
找到数据手册的内容:
如上
图,
_mux_ctrl_ofs取值为0x254,_mux_mode范围为000~110
只有_mux_mode = 0时,_select_input_ofs和_select_input才有效,其余时候_select_input_ofs和_select_input 都为0。
3、_select_input_of、_select_input
当_mux_mode = 0时,_select_input_ofs 的取值需参考数据手册:
此时_select_input_ofs=0x8e8,_select_input=0x1
4、_pad_ctrl
_pad_ctrl一般取值为0
综上所述,GPIO_19的配置宏定义如下:
#define _MX6Q_PAD_GPIO_19__KPP_COL_5 \
IOMUX_PAD(0x0624, 0x0254, 0, 0x08E8, 1, 0)
#define _MX6Q_PAD_GPIO_19__ENET_1588_EVENT0_OUT \
IOMUX_PAD(0x0624, 0x0254, 1, 0x0000, 0, 0)
#define _MX6Q_PAD_GPIO_19__SPDIF_OUT1 \
IOMUX_PAD(0x0624, 0x0254, 2, 0x0000, 0, 0)
#define _MX6Q_PAD_GPIO_19__CCM_CLKO \
IOMUX_PAD(0x0624, 0x0254, 3, 0x0000, 0, 0)
#define _MX6Q_PAD_GPIO_19__ECSPI1_RDY \
IOMUX_PAD(0x0624, 0x0254, 4, 0x0000, 0, 0)
#define _MX6Q_PAD_GPIO_19__ENET_TX_ER \
IOMUX_PAD(0x0624, 0x0254, 6, 0x0000, 0, 0)
#define _MX6Q_PAD_GPIO_19__SRC_INT_BOOT \
IOMUX_PAD(0x0624, 0x0254, 7, 0x0000, 0, 0)
以上的宏定义来自imx6的linux源码的arm/arch/palt-mxc/include/mach/iomux-mx6q.h
希望对大家有帮助~~ |
