发表于 2014-3-2 14:11:51
沙发自己坐。贴上生成的代码文件
// megafunction wizard: %RAM: 2-PORT%
// GENERATION: STANDARD
// VERSION: WM1.0
// MODULE: altsyncram
// File Name: dpram19200x16b.v
// Megafunction Name(s):
// altsyncram
// Simulation Library Files(s):
// altera_mf
// THIS IS A WIZARD-GENERATED FILE. DO NOT EDIT THIS FILE!
// 12.0 Build 178 05/31/2012 SJ Full Version
//Copyright (C) 1991-2012 Altera Corporation
//Your use of Altera Corporation's design tools, logic functions
//and other software and tools, and its AMPP partner logic
//functions, and any output files from any of the foregoing
//(including device programming or simulation files), and any
//associated documentation or information are expressly subject
//to the terms and conditions of the Altera Program License
//Subscription Agreement, Altera MegaCore Function License
//Agreement, or other applicable license agreement, including,
//without limitation, that your use is for the sole purpose of
//programming logic devices manufactured by Altera and sold by
//Altera or its authorized distributors. Please refer to the
//applicable agreement for further details.
// synopsys translate_off
`timescale 1 ps / 1 ps
// synopsys translate_on
module dpram19200x16b (
data,
rdaddress,
rdclock,
wraddress,
wrclock,
wren,
q);
input [15:0] data;
input [14:0] rdaddress;
input rdclock;
input [14:0] wraddress;
input wrclock;
input wren;
output [15:0] q;
`ifndef ALTERA_RESERVED_QIS
`endif
tri1 wrclock;
tri0 wren;
`endif
wire [15:0] sub_wire0;
wire [15:0] q = sub_wire0[15:0];
altsyncram altsyncram_component (
.address_a (wraddress),
.clock0 (wrclock),
.data_a (data),
.wren_a (wren),
.address_b (rdaddress),
.clock1 (rdclock),
.q_b (sub_wire0),
.aclr0 (1'b0),
.aclr1 (1'b0),
.addressstall_a (1'b0),
.addressstall_b (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clocken0 (1'b1),
.clocken1 (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.data_b ({16{1'b1}}),
.eccstatus (),
.q_a (),
.rden_a (1'b1),
.rden_b (1'b1),
.wren_b (1'b0));
defparam
altsyncram_component.address_aclr_b = "NONE",
altsyncram_component.address_reg_b = "CLOCK1",
altsyncram_component.clock_enable_input_a = "BYPASS",
altsyncram_component.clock_enable_input_b = "BYPASS",
altsyncram_component.clock_enable_output_b = "BYPASS",
`ifdef NO_PLI
altsyncram_component.init_file = "pic_1.rif"
`else
altsyncram_component.init_file = "pic_1.hex"
`endif
altsyncram_component.intended_device_family = "Cyclone IV E",
altsyncram_component.lpm_type = "altsyncram",
altsyncram_component.numwords_a = 19200,
altsyncram_component.numwords_b = 19200,
altsyncram_component.operation_mode = "DUAL_PORT",
altsyncram_component.outdata_aclr_b = "NONE",
altsyncram_component.outdata_reg_b = "CLOCK1",
altsyncram_component.power_up_uninitialized = "FALSE",
altsyncram_component.widthad_a = 15,
altsyncram_component.widthad_b = 15,
altsyncram_component.width_a = 16,
altsyncram_component.width_b = 16,
altsyncram_component.width_byteena_a = 1;
endmodule
// CNX file retrieval info
// Retrieval info: PRIVATE: ADDRESSSTALL_A NUMERIC "0"
// Retrieval info: PRIVATE: ADDRESSSTALL_B NUMERIC "0"
// Retrieval info: PRIVATE: BYTEENA_ACLR_A NUMERIC "0"
// Retrieval info: PRIVATE: BYTEENA_ACLR_B NUMERIC "0"
// Retrieval info: PRIVATE: BYTE_ENABLE_A NUMERIC "0"
// Retrieval info: PRIVATE: BYTE_ENABLE_B NUMERIC "0"
// Retrieval info: PRIVATE: BYTE_SIZE NUMERIC "8"
// Retrieval info: PRIVATE: BlankMemory NUMERIC "0"
// Retrieval info: PRIVATE: CLOCK_ENABLE_INPUT_A NUMERIC "0"
// Retrieval info: PRIVATE: CLOCK_ENABLE_INPUT_B NUMERIC "0"
// Retrieval info: PRIVATE: CLOCK_ENABLE_OUTPUT_A NUMERIC "0"
// Retrieval info: PRIVATE: CLOCK_ENABLE_OUTPUT_B NUMERIC "0"
// Retrieval info: PRIVATE: CLRdata NUMERIC "0"
// Retrieval info: PRIVATE: CLRq NUMERIC "0"
// Retrieval info: PRIVATE: CLRrdaddress NUMERIC "0"
// Retrieval info: PRIVATE: CLRrren NUMERIC "0"
// Retrieval info: PRIVATE: CLRwraddress NUMERIC "0"
// Retrieval info: PRIVATE: CLRwren NUMERIC "0"
// Retrieval info: PRIVATE: Clock NUMERIC "1"
// Retrieval info: PRIVATE: Clock_A NUMERIC "0"
// Retrieval info: PRIVATE: Clock_B NUMERIC "0"
// Retrieval info: PRIVATE: IMPLEMENT_IN_LES NUMERIC "0"
// Retrieval info: PRIVATE: INDATA_ACLR_B NUMERIC "0"
// Retrieval info: PRIVATE: INDATA_REG_B NUMERIC "0"
// Retrieval info: PRIVATE: INIT_FILE_LAYOUT STRING "PORT_B"
// Retrieval info: PRIVATE: INIT_TO_SIM_X NUMERIC "0"
// Retrieval info: PRIVATE: INTENDED_DEVICE_FAMILY STRING "Cyclone IV E"
// Retrieval info: PRIVATE: JTAG_ENABLED NUMERIC "0"
// Retrieval info: PRIVATE: JTAG_ID STRING "NONE"
// Retrieval info: PRIVATE: MAXIMUM_DEPTH NUMERIC "0"
// Retrieval info: PRIVATE: MEMSIZE NUMERIC "307200"
// Retrieval info: PRIVATE: MEM_IN_BITS NUMERIC "0"
// Retrieval info: PRIVATE: MIFfilename STRING "pic_1.hex"
// Retrieval info: PRIVATE: OPERATION_MODE NUMERIC "2"
// Retrieval info: PRIVATE: OUTDATA_ACLR_B NUMERIC "0"
// Retrieval info: PRIVATE: OUTDATA_REG_B NUMERIC "1"
// Retrieval info: PRIVATE: RAM_BLOCK_TYPE NUMERIC "0"
// Retrieval info: PRIVATE: READ_DURING_WRITE_MODE_MIXED_PORTS NUMERIC "2"
// Retrieval info: PRIVATE: READ_DURING_WRITE_MODE_PORT_A NUMERIC "3"
// Retrieval info: PRIVATE: READ_DURING_WRITE_MODE_PORT_B NUMERIC "3"
// Retrieval info: PRIVATE: REGdata NUMERIC "1"
// Retrieval info: PRIVATE: REGq NUMERIC "1"
// Retrieval info: PRIVATE: REGrdaddress NUMERIC "1"
// Retrieval info: PRIVATE: REGrren NUMERIC "1"
// Retrieval info: PRIVATE: REGwraddress NUMERIC "1"
// Retrieval info: PRIVATE: REGwren NUMERIC "1"
// Retrieval info: PRIVATE: SYNTH_WRAPPER_GEN_POSTFIX STRING "0"
// Retrieval info: PRIVATE: USE_DIFF_CLKEN NUMERIC "0"
// Retrieval info: PRIVATE: UseDPRAM NUMERIC "1"
// Retrieval info: PRIVATE: VarWidth NUMERIC "0"
// Retrieval info: PRIVATE: WIDTH_READ_A NUMERIC "16"
// Retrieval info: PRIVATE: WIDTH_READ_B NUMERIC "16"
// Retrieval info: PRIVATE: WIDTH_WRITE_A NUMERIC "16"
// Retrieval info: PRIVATE: WIDTH_WRITE_B NUMERIC "16"
// Retrieval info: PRIVATE: WRADDR_ACLR_B NUMERIC "0"
// Retrieval info: PRIVATE: WRADDR_REG_B NUMERIC "0"
// Retrieval info: PRIVATE: WRCTRL_ACLR_B NUMERIC "0"
// Retrieval info: PRIVATE: enable NUMERIC "0"
// Retrieval info: PRIVATE: rden NUMERIC "0"
// Retrieval info: LIBRARY: altera_mf altera_mf.altera_mf_components.all
// Retrieval info: CONSTANT: ADDRESS_ACLR_B STRING "NONE"
// Retrieval info: CONSTANT: ADDRESS_REG_B STRING "CLOCK1"
// Retrieval info: CONSTANT: CLOCK_ENABLE_INPUT_A STRING "BYPASS"
// Retrieval info: CONSTANT: CLOCK_ENABLE_INPUT_B STRING "BYPASS"
// Retrieval info: CONSTANT: CLOCK_ENABLE_OUTPUT_B STRING "BYPASS"
// Retrieval info: CONSTANT: INIT_FILE STRING "pic_1.hex"
// Retrieval info: CONSTANT: INTENDED_DEVICE_FAMILY STRING "Cyclone IV E"
// Retrieval info: CONSTANT: LPM_TYPE STRING "altsyncram"
// Retrieval info: CONSTANT: NUMWORDS_A NUMERIC "19200"
// Retrieval info: CONSTANT: NUMWORDS_B NUMERIC "19200"
// Retrieval info: CONSTANT: OPERATION_MODE STRING "DUAL_PORT"
// Retrieval info: CONSTANT: OUTDATA_ACLR_B STRING "NONE"
// Retrieval info: CONSTANT: OUTDATA_REG_B STRING "CLOCK1"
// Retrieval info: CONSTANT: POWER_UP_UNINITIALIZED STRING "FALSE"
// Retrieval info: CONSTANT: WIDTHAD_A NUMERIC "15"
// Retrieval info: CONSTANT: WIDTHAD_B NUMERIC "15"
// Retrieval info: CONSTANT: WIDTH_A NUMERIC "16"
// Retrieval info: CONSTANT: WIDTH_B NUMERIC "16"
// Retrieval info: CONSTANT: WIDTH_BYTEENA_A NUMERIC "1"
// Retrieval info: USED_PORT: data 0 0 16 0 INPUT NODEFVAL "data[15..0]"
// Retrieval info: USED_PORT: q 0 0 16 0 OUTPUT NODEFVAL "q[15..0]"
// Retrieval info: USED_PORT: rdaddress 0 0 15 0 INPUT NODEFVAL "rdaddress[14..0]"
// Retrieval info: USED_PORT: rdclock 0 0 0 0 INPUT NODEFVAL "rdclock"
// Retrieval info: USED_PORT: wraddress 0 0 15 0 INPUT NODEFVAL "wraddress[14..0]"
// Retrieval info: USED_PORT: wrclock 0 0 0 0 INPUT VCC "wrclock"
// Retrieval info: USED_PORT: wren 0 0 0 0 INPUT GND "wren"
// Retrieval info: CONNECT: @address_a 0 0 15 0 wraddress 0 0 15 0
// Retrieval info: CONNECT: @address_b 0 0 15 0 rdaddress 0 0 15 0
// Retrieval info: CONNECT: @clock0 0 0 0 0 wrclock 0 0 0 0
// Retrieval info: CONNECT: @clock1 0 0 0 0 rdclock 0 0 0 0
// Retrieval info: CONNECT: @data_a 0 0 16 0 data 0 0 16 0
// Retrieval info: CONNECT: @wren_a 0 0 0 0 wren 0 0 0 0
// Retrieval info: CONNECT: q 0 0 16 0 @q_b 0 0 16 0
// Retrieval info: GEN_FILE: TYPE_NORMAL dpram19200x16b.v TRUE
// Retrieval info: GEN_FILE: TYPE_NORMAL dpram19200x16b.inc FALSE
// Retrieval info: GEN_FILE: TYPE_NORMAL dpram19200x16b.cmp FALSE
// Retrieval info: GEN_FILE: TYPE_NORMAL dpram19200x16b.bsf FALSE
// Retrieval info: GEN_FILE: TYPE_NORMAL dpram19200x16b_inst.v FALSE
// Retrieval info: GEN_FILE: TYPE_NORMAL dpram19200x16b_bb.v FALSE
// Retrieval info: LIB_FILE: altera_mf
