大家如果在调试KL25第10版sample code代码的BME工程时,发现打印出的结果显示BME代码确没有普通C代码跑的快,请不要惊慌,本文教您如何解决!
由于第10版SC中BME.h 头文件写的比较冗余,不利于体现BME的优势,先将头文件做如下改写:
这里以BME_AND_W 函数为例。
原描写方式为:
- _BME_INLINE void BME_AND_W (volatile uint32_t *addr, register uint32_t wdata)
- *(volatile uint32_t*)((uint32_t)addr | BME_AND_MASK) = wdata;
先修改为宏定义的方式:
- #define BME_AND_W(addr, wdata) \
最终的打印结果显示为:
- Running the LQRUG_bme_ex1 project.
- systick start value: 0xFFFFF2
- systick end value: 0xFFFFEE
- systick current value read overhead: 0x4
- systick start value: 0xFFFFD6
- systick end value: 0xFFFFC2
- actual execution cycle for logic operation with normal C code: 0x10
- systick start value: 0xFFFFD7
- systick end value: 0xFFFFC9
- actual execution cycle for logic operation with BME macros: 0xA
- systick start value: 0xFFFFE7
- systick end value: 0xFFFFD3
- actual execution cycle for BFI operation with normal C: 0x10
- systick start value: 0xFFFFEE
- systick end value: 0xFFFFE0
- actual execution cycle for BFI operation with BME macro: 0xA
- load_bit is 1
- systick start value: 0xFFFFDF
- systick end value: 0xFFFFCB
- actual execution cycle for LAC1 operation with normal C: 0x10
- load bit is 1
- systick start value: 0xFFFFE4
- systick end value: 0xFFFFD6
- actual execution cycle for LAC1 operation with BME macro: 0xA
- load_bit is 0
- systick start value: 0xFFFFEA
- systick end value: 0xFFFFD7
- actual execution cycle for LAS1 operation with normal C: 0xF
- load bit is 0
- systick start value: 0xFFFFE3
- systick end value: 0xFFFFD4
- actual execution cycle for LAS1 operation with bme macro: 0xB
- extracted data is 2
- systick start value: 0xFFFFE9
- systick end value: 0xFFFFD8
- actual execution cycle for UBFX operation with normal C: 0xD
- systick start value: 0xFFFFEF
- systick end value: 0xFFFFE2
- actual execution cycle for UBFX operation with bme macro: 0x9
结果体现了使用BME模块的优势。
附件为修改后的BME.h,需要的网友可以下载下来将代码包中的头文件直接替换即可。
PS:本帖可从飞思卡尔版块置顶帖:飞思卡尔Kinetis资料大本营的飞思卡尔论坛支持小组【经验分享】帖汇总链接进入。 |
