发表于 2014-8-8 19:51:11
2014年TI杯电子设计竞赛推荐芯片列表:
电源类 MOSFET驱动器 TPS28225DR 8-Pin High Frequency 4-Amp Sink Synchronous MOSFET Driver
UCC27211DDAR 120V Boot, 4A Peak, High Frequency High-Side Low-Side Driver
降压开关电源,MOS管内置 TPS54340DDAR 42 V Input, 3.5 A, Step-Down DC/DC Converter with Eco-mode™
TPS56528DDAR 4.5V to 18V Input, 5-A Synchronous Step-Down Converter with Advanced Eco-mode™
降压线性电源 TPS7A1601QDGNRQ1 Automotive Catalog 60V, 5-µA Iq, 100-mA, Low-Dropout Voltage Regulator with Enable and Power Good
降压线性电源 TPS7A4001DGNR 100V Input, 50mA, Single Output Low-Dropout Linear Regulator
升压开关电源,MOS管外置 TPS40210DGQR Wide Input Range Current Mode Boost Controller
MOS管 CSD19535KCS 100V, N-Channel NexFET™ Power MOSFET
电流检测芯片 INA210AIDCKR Voltage Output, High/Low-Side Measurement, Bi-Directional Zero-Drift Series Current Shunt Monitor
INA282AIDR Wide Common Mode Range, Bidirectional, High Accuracy Current Shunt Monitor
高速放大器 电流反馈 THS3201D 1.8GHz Current Feedback Amplifier
LMH6703MF/NOPB 1.2 GHz, Low Distortion Op Amp with Shutdown
OPA2695ID Dual, Ultra-Wideband, Current-Feedback Operational Amplifier with Disable
差分输入压控增益放大器 VCA821ID Wideband, > 40dB Adjust Range, Linear in dB Variable Gain Amplifier
全差分放大器 LMH6552MA/NOPB 1.5 GHz Fully Differential Amplifier
电压反馈 OPA842IDR Wideband, Low Distortion, Unity Gain Stable, Voltage Feedback Operational Amplifier
5V 电压反馈 OPA2356AIDR 2.5V, 200MHz GBW, CMOS Dual Op Amp
精密ADC/DAC Delta-Sigma ADS1118IDGSR 16-Bit ADC with Integrated MUX, PGA, Temperature Sensor, Oscillator, and Reference
Multiplying DAC, R-2R DAC7811IDGSR 12-Bit, Serial Input, Multiplying Digital to Analog Converter
R-String DAC DAC8571IDGKR Low-Power Rail-To-Rail Output 16-Bit I2C Input DAC
3V 参考源 REF3330AIDBZR 30ppm/C Drift, 3.9uA, SOT23-3, SC70-3 Voltage Reference
精密放大器 5V CMOS 仪表放大器 INA333AIDGKR Low Power, Precision Instrumentation Amplifier
36V 仪表放大器 INA826AID Precision, 200-μA Supply Current, 36-V Supply Instrumentation Amplifier
36V 精密放大器 OPA192IDR High Voltage, Rail-to-Rail Input/Output,Precision Op Amps,GBW = 10MHz
5V CMOS 放大器 OPA2320AIDGKR Precision, 20MHz, 0.9pA Ib, RRIO, CMOS Operational Amplifier
5V CMOS 放大器 OPA2330AIDR 1.8V, 35µA, microPower, Precision, Zero Drift CMOS Op Amp
5V CMOS 放大器 OPA2376AIDR Precision, Low Noise, Low Quiescent Current Operational Amplifier
音频功放 D类25W功放 TPA3112D1PWPR 25-W Filter-Free Mono Class-D Audio Amplifier with SpeakerGuard™ (TPA3112)
其他 高速比较器 TLV3501AIDR 4.5ns Rail-to-Rail, High Speed Comparator in Microsized Packages
1bit 数字缓冲器 SN74AUP1G07DBVR Low-Power Single Buffer/Driver with Open-Drain Outputs
5V 2选一模拟开关 TS5A3159DBVR 1-Ohm SPDT Analog Switch
5V 单通道模拟开关 TS5A3166DBVR
12V 单通道模拟开关 TS12A4515DR
