发表于 2013-12-22 10:09:34
SN820X 2.4GHz Wi-Fi® 802.11b/g/n
The SN820X is a family of small, low power, self-contained, certified Wi-Fi® network controller modules that provide simple serial-to-Wi-Fi® connectivity to the internet.
These modules are an ideal solution for device manufacturers who are looking to add wireless connectivity to home appliances, smart energy systems, healthcare and industrial control equipment.
The SN820X modules are enabled with Broadcom Corporation’s Wireless Internet Connectivity for Embedded Devices (WICED) architecture.
They host the Wi-Fi®, TCP/IP network stack, security supplicant, and other network application features.
The modules are provided with Murata Simple Network Interface Connection (SNIC) software and EZ Web Wizzard™ software.
They are also compatible with Broadcom WICED SDK.
这个 Broadcom WICED SDK 那里可以下载到啊?
Features
• 2.4GHz IEEE 802.11b/g/n radio technology
• Wi-Fi chipset: Broadcom BCM43362
• Built-in MCU: ST Microelectronics STM32 ARM Cortex-M3
• Dimension: 30.5 mm x 19.4 mm x 2.8 mm
• On-board antenna or U.FL connector
• Transmit power: +18 dBm @b mode/11Mpbs
• Max receive sensitivity: -96dbm
• Host interface: UART, SPI
• Sensor applications support: I2C, GPIO, ADC, DAC
• Operating from -40ºC to 85ºC
• ROHS compliant
• FCC/IC certified; CE compliant
• Supports AP/STA Dual mode
• Supports built‐in TCP/IP, HTTP, Javascript, and Web Server with SNIC software package
• Supports custom web pages with Murata EZ Web Wizzard™ Software
• Supports Broadcom WICED™ SDK
