回复: 12
继C51精确延时函数,再次写的PIC18精确延时函数
发表于 2012-2-18 12:48:34 | 显示全部楼层 |阅读模式
/* PIC18 software interface header */
#define Fosc 11059200                    //XTAL = 11.0592MHz
#define Fcy    (Fosc/4)                    //2764800Hz
void
User_Delay_Ms(uchar number)    //delay=((((num1*4)+4)*num2+6)*number+13)/Fcy
    static unsigned char     num1,
                         num2;
    do
        num2 = 10;
        do
            num1 = Fcy/40322;
            while(--num1);
        }while(--num2);
    }while(--number);
欢迎测试!
 楼主| 发表于 2012-2-18 12:49:36 | 显示全部楼层
C51精确延时函数地址:
http://www.ourdev.cn/bbs/bbs_content.jsp?bbs_sn=4925141&bbs_page_no=1&search_mode=3&search_text=wangqh1983&bbs_id=9999
发表于 2012-2-18 13:38:25 | 显示全部楼层
即C51精确延时函数,再次写的PIC18精确延时函数
即——继
进来后才明白。
 楼主| 发表于 2012-2-18 17:41:36 | 显示全部楼层
(原文件名:2012-2-18 17-41-27.png)
 楼主| 发表于 2012-2-18 18:29:27 | 显示全部楼层
可以在头文件定义系统时钟!
(原文件名:2012-2-18 18-28-47.png)
发表于 2012-2-18 19:49:06 | 显示全部楼层
usually, you don't need that precise of a delay: something in the rough neighbor would typically work.
plus, if you have interrupt,  your delay routines will produce different actual delays.
"num1 = Fcy/40322;     "
I would redefine 40322 so that it can be easily changed when you move the routine to a different chip / architecture.
"            while(--num1);     "
this will create a problem when num1 is calculated to be 0 - from very low Fcy for example. I would use "while (num1--) continue;" instead.
I use a similar approach, except that mine was built up, from delay(cycles); to delay_us(us) which calls delay() and then delay_ms(ms) which calls delay_us(), all of which is based on pre-defined F_CPU.
this allows the code to be fairly easily ported.
发表于 2012-2-21 12:49:39 | 显示全部楼层
感谢!!
 楼主| 发表于 2012-2-25 11:53:59 | 显示全部楼层
感谢你的评说,不过也确实有道理。
但是这个形参如果输入0,将是错误的;不过也让人很难理解。不会有人需要0ms的延时吧。有些时候要求时序比较严格的情况下,我们可以将总中断关闭。
发表于 2012-2-25 20:59:19 | 显示全部楼层
"不会有人需要0ms的延时吧。"
it is about the (predictable) behavior of the code: delay_ms(2) is 1 ms, delay_ms(1) is 1ms, delay_ms(0) is 256ms (or32kms, depending on the data type).
that kind of behavior is unexpected for most people.
 楼主| 发表于 2012-2-26 07:25:27 | 显示全部楼层
(原文件名:2012-2-26 7-23-49.png)
这个不会啊,但是输入0是错误的。
 楼主| 发表于 2012-2-26 07:38:14 | 显示全部楼层
如果将代码改成while(number--);汇编代码将会增加,须从新计算Tcy。
发表于 2014-3-27 13:38:48 | 显示全部楼层
感谢分享!
发表于 2014-3-27 15:58:10 | 显示全部楼层
考虑到中断了吗?呵呵
GMT+8, 2024-7-29 10:22
