最近想用STM32搞个HID键盘。参考了圈圈的代码。各种描述符基本上用的是电脑圈圈的。现在出现个问题:在进系统以后键盘使用正常。在开机的时候按DELETE键不能进入BIOS。请路过的朋友分析是什么问题,TKS。
附上描述符代码:
const u8 CustomHID_DeviceDescriptor[CUSTOMHID_SIZ_DEVICE_DESC] =
0x12, /*bLength */
USB_DEVICE_DESCRIPTOR_TYPE, /*bDescriptorType*/
0x01, /*bcdUSB */
0x10,
0x00, /*bDeviceClass*/
0x00, /*bDeviceSubClass*/
0x00, /*bDeviceProtocol*/
0x40, /*bMaxPacketSize40*/
0xf3, /*idVendor (0x0483)*/
0x04,
0x04, /*idProduct = 0x5750*/
0x01,
0x00, /*bcdDevice rel. 2.00*/
0x02,
1, /*Index of string descriptor describing
manufacturer */
2, /*Index of string descriptor describing
product*/
3, /*Index of string descriptor describing the
device serial number */
0x01 /*bNumConfigurations*/
; /* CustomHID_DeviceDescriptor */
/* USB Configuration Descriptor */
/* All Descriptors (Configuration, Interface, Endpoint, Class, Vendor */
const u8 CustomHID_ConfigDescriptor[CUSTOMHID_SIZ_CONFIG_DESC] =
0x09, /* bLength: Configuation Descriptor size */
USB_CONFIGURATION_DESCRIPTOR_TYPE, /* bDescriptorType: Configuration */
CUSTOMHID_SIZ_CONFIG_DESC,
/* wTotalLength: Bytes returned */
0x00,
0x01, /* bNumInterfaces: 1 interface */
0x01, /* bConfigurationValue: Configuration value */
0x00, /* iConfiguration: Index of string descriptor describing
the configuration*/
0xC0, /* bmAttributes: Bus powered */
0x32, /* MaxPower 100 mA: this current is used for detecting Vbus */
/************** Descriptor of Custom HID interface ****************/
/* 09 */
0x09, /* bLength: Interface Descriptor size */
USB_INTERFACE_DESCRIPTOR_TYPE,/* bDescriptorType: Interface descriptor type */
0x00, /* bInterfaceNumber: Number of Interface */
0x00, /* bAlternateSetting: Alternate setting */
0x02, /* bNumEndpoints */
0x03, /* bInterfaceClass: HID */
0x01, /* bInterfaceSubClass : 1=BOOT, 0=no boot */
0x01, /* nInterfaceProtocol : 0=none, 1=keyboard, 2=mouse */
0, /* iInterface: Index of string descriptor */
/******************** Descriptor of Custom HID HID ********************/
/* 18 */
0x09, /* bLength: HID Descriptor size */
HID_DESCRIPTOR_TYPE, /* bDescriptorType: HID */
0x00, /* bcdHID: HID Class Spec release number */
0x01,
0x00, /* bCountryCode: Hardware target country */
0x01, /* bNumDescriptors: Number of HID class descriptors to follow */
0x22, /* bDescriptorType */
CUSTOMHID_SIZ_REPORT_DESC,/* wItemLength: Total length of Report descriptor */
0x00,
/******************** Descriptor of Custom HID endpoints ******************/
/* 27 */
0x07, /* bLength: Endpoint Descriptor size */
USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType: */
0x81, /* bEndpointAddress: Endpoint Address (IN) */
0x03, /* bmAttributes: Interrupt endpoint */
0x08, /* wMaxPacketSize: 16 Bytes max */
0x00,
0x20, /* bInterval: Polling Interval (32 ms) */
/* 34 */
/* Endpoint descriptor type */
0x01, /* bEndpointAddress: */
/* Endpoint Address (OUT) */
0x00,
0x20, /* bInterval: Polling Interval (20 ms) */
/* 41 */
; /* CustomHID_ConfigDescriptor */
const u8 CustomHID_ReportDescriptor[CUSTOMHID_SIZ_REPORT_DESC] =
0x05, 0x01, // USAGE_PAGE (Generic Desktop)
0x09, 0x06, // USAGE (Keyboard)
0xa1, 0x01, // COLLECTION (Application)
0x05, 0x07, // USAGE_PAGE (Keyboard/Keypad)
0x19, 0xe0, // USAGE_MINIMUM (Keyboard LeftControl)
0x29, 0xe7, // USAGE_MAXIMUM (Keyboard Right GUI)
0x15, 0x00, // LOGICAL_MINIMUM (0)
0x25, 0x01, // LOGICAL_MAXIMUM (1)
0x95, 0x08, // REPORT_COUNT (8)
0x75, 0x01, // REPORT_SIZE (1)
0x81, 0x02, // INPUT (Data,Var,Abs)
0x95, 0x01, // REPORT_COUNT (1)
0x75, 0x08, // REPORT_SIZE (8)
0x81, 0x03, // INPUT (Cnst,Var,Abs)
0x95, 0x06, // REPORT_COUNT (6)
0x25, 0xFF, // LOGICAL_MAXIMUM (255)
0x19, 0x00, // USAGE_MINIMUM (Reserved (no event indicated))
0x29, 0x65, // USAGE_MAXIMUM (Keyboard Application)
0x81, 0x00, // INPUT (Data,Ary,Abs)
0x95, 0x02, // REPORT_COUNT (2)
0x05, 0x08, // USAGE_PAGE (LEDs)
0x19, 0x01, // USAGE_MINIMUM (Num Lock)
0x29, 0x02, // USAGE_MAXIMUM (Caps Lock)
0x91, 0x02, // OUTPUT (Data,Var,Abs)
0x75, 0x06, // REPORT_SIZE (6)
0x91, 0x03, // OUTPUT (Cnst,Var,Abs)
0xc0 // END_COLLECTION
}; /* CustomHID_ReportDescriptor */
/* USB String Descriptors (optional) */
const u8 CustomHID_StringLangID[CUSTOMHID_SIZ_STRING_LANGID] =
CUSTOMHID_SIZ_STRING_LANGID,
USB_STRING_DESCRIPTOR_TYPE,
0x09,
0x04
; /* LangID = 0x0409: U.S. English */
const u8 CustomHID_StringVendor[CUSTOMHID_SIZ_STRING_VENDOR] =
CUSTOMHID_SIZ_STRING_VENDOR, /* Size of Vendor string */
USB_STRING_DESCRIPTOR_TYPE, /* bDescriptorType*/
/* Manufacturer: "STMicroelectronics" */
'S', 0, 'T', 0, 'M', 0, 'i', 0, 'c', 0, 'r', 0, 'o', 0, 'e', 0,
'l', 0, 'e', 0, 'c', 0, 't', 0, 'r', 0, 'o', 0, 'n', 0, 'i', 0,
'c', 0, 's', 0
const u8 CustomHID_StringProduct[CUSTOMHID_SIZ_STRING_PRODUCT] =
CUSTOMHID_SIZ_STRING_PRODUCT, /* bLength */
USB_STRING_DESCRIPTOR_TYPE, /* bDescriptorType */
'S', 0, 'T', 0, 'M', 0, '3', 0, '2', 0, ' ', 0, 'C', 0,
'u', 0, 's', 0, 't', 0, 'm', 0, ' ', 0, 'H', 0, 'I', 0,
'D', 0
u8 CustomHID_StringSerial[CUSTOMHID_SIZ_STRING_SERIAL] =
CUSTOMHID_SIZ_STRING_SERIAL, /* bLength */
'S', 0, 'T', 0, 'M', 0,'3', 0,'2', 0, '1', 0, '0', 0
