发表于 2009-9-27 23:37:56
【38楼】 chenfeng032 晨风
如果500块买个国产电源,我还不如买个二手的KENWOOD电源,我买了一个下面连接的型号,没有在淘宝买,直接去广州试了搬回来。99成新,一点划伤也没有,700大洋。很好用。
http://item.taobao.com/auction/item_detail-0db1-4f8abeef98364ba289561723374c5f60.htm?cm_cat=0
Kenwood PWR18 - 2 Power Supply 2 Output 18V / 2A
POWER SUPPLIES (Multiple Output)
PWR18 - 2 Digital Display
SPECIFICATIONS:
Output
Output voltage range (V): 0 - ±18V
Output current range (A): 0 - ±2A
Voltage Regulation Characteristics:
Line regulation: 1mV
Load regulation: 3mV
Ripple /Noise: 0.5mVrms
Current Regulation Characteristics:
Line regulation:2mA (Typ.)
Load regulation: 10mA (Typ.)
Digital Meter Display:
Voltage display: Maximum 19.99V (fixed range: LED)
Current display: Maximum 9.99A (fixed range: LED)
Power Consumption VA/W (100V AC, 20%): Approx. 210VA/165W
Case Dimensions: 104 (W) X 147 (H) X 330 (D) mm
Weight: Approx. 6.4kg
Accessories: Instruction Manual, Power Cable, Modular Cable |
