IC regulators like LM317 typically are good for up to 40v, not much more for the HV versions.
Tube amplifiers typically require much higher voltage at very low current levels. so how do you use a low voltage regulator in such a high voltage situation?
you use pre-regulation, like the Maida Regulator. In a pre-regulation, you use another high voltage device, either a BJT or a MOSFET, to drop most of the voltages and then use a low voltage regulator, like LM317, to regulate the rest. This has the advantage of being able to regulate very high voltages - depending on the discrete regulator, yet at very low cost / parts count, and ripple rejection.
Here is a schematic for the Maida regulator.
(原文件名:LM317 - Maida Regulator.PNG)
D1 controls the voltage drop over the IC regulator (=D1's Vz - Vgs - Iout*R2 = 6v). Output voltage is approximately 1.25v/R5*(R5+PV1).
Walter Jung also has a similar design. |
