发表于 2010-3-21 11:45:07
“情况不明的时候,先从必须要做的东西开始入手”
开发一个较大的项目,由于最终实现的功能可能较为复杂,则在项目的一开始就要求
较为精确的规划,对很多初学者来说,是相当有难度得,也不现实。比较现实的做法是:
<font color=blue>从必须要做的事情入手,然后将遇到的新问题分类,再次找到必须要做的事情,最终完成
大部分工作。
这种开发方式有其局限性,不过很容易通过经验的积累来弥补这种局限。至于是什么
局限,开发的经验会告诉你。
废话少说,一个HexFileStream最重要且最先要做的,当然是能够从Hex文件中解码出
我们需要的数据啦。所以,做一个Record类不用犹豫。
Record.h
using System;
using System.Collections.Generic;
using System.Text;
namespace Utilities.IO
//! \name record structure in Intel-Hexadecimal file
internal abstract class Record
protected Boolean m_bAvailable = false;
//! \brief property for check whether this record is available or not.
public Boolean Available
get { return m_bAvailable; }
//! \name record type
internal enum Type : byte
DATA_RECORD = 0, //!< data record
END_OF_FILE_RECORD = 1, //!< end of file record
EXTEND_SEGMENT_ADDRESS_RECORD = 2, //!< extend segment address record
START_SEGMENT_ADDRESS_RECORD = 3, //!< start segment address record
EXTEND_LINEAR_ADDRESS_RECORD = 4, //!< extend linear address record
START_LINEAR_ADDRESS_RECORD = 5 //!< start linear address record
//! \brief property for getting record type
/*! \note Each record has a RECTYP field which specifies the record type of this record.
* The RECTYP field is used to interpret the remaining information within the
* record. The encoding for all the current record types are:
* ’00’ Data Record
* ’01’ End of File Record
* ’02’ Extended Segment Address Record
* ’03’ Start Segment Address Record
* ’04’ Extended Linear Address Record
* ’05’ Start Linear Address Record
public abstract Type RecordType
get;
/*! \note Each record has a RECLEN field which specifies the number of bytes of
* information or data which follows the RECTYP field of the record. Note that
* one data byte is represented by two ASCII characters. The maximum value of
* the RECLEN field is hexadecimal ’FF’ or 255.
public abstract Int32 RecordLength
get;
/*! \note Each record has a LOAD OFFSET field which specifies the 16-bit starting load
* offset of the data bytes, therefore this field is only used for Data Records.
* In other records where this field is not used, it should be coded as four
* ASCII zero characters (’0000’ or 03030303OH).
public virtual UInt16 LoadOffset
get { return 0; }
/*! \note Each record has a variable length INFO/DATA field, it consists of zero or
* more bytes encoded as pairs of hexadecimal digits. The interpretation of
* this field depends on the RECTYP field.
public abstract Byte[] Data
get;
//! \brief method to parse record string
//! \param tHexRecord a record string
//! \return a reference to a new record object
public static Record Parse(String tHexRecord)
//! check input
if (null == tHexRecord)
return null;
tHexRecord = tHexRecord.Trim().ToUpper();
if ("" == tHexRecord)
return null;
//! \brief check record head
if (':' != tHexRecord[0])
return null;
if (!IsHexNumber(tHexRecord.Substring(1)))
return null;
Int32 tRecordLength = 0;
Int32 tCheckSUM = 0;
Int32 tLoadOffSet = 0;
Byte tRecordType = 0;
Byte[] tData = null;
//! try to get record length
try
tRecordLength = Int32.Parse(tHexRecord.Substring(1, 2), System.Globalization.NumberStyles.AllowHexSpecifier);
catch (Exception Err)
Err.ToString();
return null;
tCheckSUM += tRecordLength;
//! check record string length
if (tHexRecord.Length < (11 + tRecordLength * 2))
//! incomplete record
return null;
//! try to get LoadOffset
try
tLoadOffSet = UInt16.Parse(tHexRecord.Substring(3,4), System.Globalization.NumberStyles.AllowHexSpecifier);
Err.ToString();
return null;
tCheckSUM += tLoadOffSet >> 8;
tCheckSUM += tLoadOffSet & 0xFF;
//! try to get record type
try
tRecordType = Byte.Parse(tHexRecord.Substring(7, 2), System.Globalization.NumberStyles.AllowHexSpecifier);
Err.ToString();
return null;
//! check record type value
if (tRecordType > 5)
return null;
else if (
((Type)tRecordType != Type.DATA_RECORD)
&& (tLoadOffSet != 0)
//! illegal record loadoffset
return null;
tCheckSUM += tRecordType;
//! get data byte
tData = new Byte[tRecordLength];
if (null == tData)
//! failed to allocated memory
return null;
//! read all data bytes in a record
for (Int32 n = 0; n < tData.Length; n++)
try
tData[n] = Byte.Parse(tHexRecord.Substring(9 + n * 2, 2), System.Globalization.NumberStyles.AllowHexSpecifier);
Err.ToString();
return null;
tCheckSUM += tData[n];
//! get check sum
try
tCheckSUM += Byte.Parse(tHexRecord.Substring(9 + tData.Length * 2, 2), System.Globalization.NumberStyles.AllowHexSpecifier);
Err.ToString();
return null;
if (0 != (tCheckSUM & 0xFF))
//! check sum error
return null;
//! \brief check record type
switch ((Type)tRecordType)
case Type.DATA_RECORD: //!< data record
return new DataRecord((UInt16)tLoadOffSet, tData);
case Type.END_OF_FILE_RECORD: //!< EOF record
return new EndOfFileRecord();
case Type.EXTEND_LINEAR_ADDRESS_RECORD: //!< extend linear address record
return new ExtendLinearAddressRecord(tData);
case Type.EXTEND_SEGMENT_ADDRESS_RECORD: //!< extend segment address
return new ExtendSegmentAddressRecord(tData);
case Type.START_LINEAR_ADDRESS_RECORD: //!< start linear address record
return new StartLinearAddressRecord(tData);
case Type.START_SEGMENT_ADDRESS_RECORD:
return new StartSegmentAddressRecord(tData); //!< start segment address
default:
//! brief no such type
return null;
return null;
//! \brief get HEX record String
public override String ToString()
StringBuilder tsbHexRecord = new StringBuilder();
if (m_bAvailable)
return null;
UInt32 tCheckSUM = 0;
//! record head
tsbHexRecord.Append(':');
//! record length
tsbHexRecord.Append(this.RecordLength.ToString("X2"));
tCheckSUM += (UInt32)RecordLength;
//! record load offset
tsbHexRecord.Append(this.LoadOffset.ToString("X4"));
tCheckSUM += (UInt32)(LoadOffset & 0x00FF);
tCheckSUM += (UInt32)(LoadOffset >> 8);
//! record type
tsbHexRecord.Append(((Byte)this.RecordType).ToString("X2"));
tCheckSUM += (Byte)RecordType;
//! record data
foreach (Byte tItem in Data)
tsbHexRecord.Append(tItem.ToString("X2"));
tCheckSUM += tItem;
//! record check sum
tsbHexRecord.Append(((Byte)((UInt16)0x100 - (UInt16)(tCheckSUM & 0xFF))).ToString("X2"));
return tsbHexRecord.ToString();
//! \brief method for check whecher string only consist of hex value
static public Boolean IsHexNumber(String tHexString)
if (null == tHexString)
return false;
tHexString = tHexString.Trim().ToUpper();
if ("" == tHexString)
return false;
foreach (Char tSymble in tHexString.ToCharArray())
if (!Char.IsNumber(tSymble))
if ((tSymble < 'A') || (tSymble > 'F'))
return false;
return true;
/*! \note The End of File Record specifies the end of the hexadecimal object
* file.
//! \name the End of File record
internal class EndOfFileRecord : Record
//! \brief length always is zero.
public override int RecordLength
get { return 0; }
//! \brief get record type
public override Record.Type RecordType
get { return Type.END_OF_FILE_RECORD; }
//! \brief no data
public override byte[] Data
get
return new Byte[0];
/*! \note The 32-bit Extended Linear Address Record is used to specify bits
* 16-31 of the Linear Base Address (LBA), where bits 0-15 of the LBA
* are zero. Bits 16-31 of the LBA are referred to as the Upper Linear
* Base Address (ULBA). The absolute memory address of a content byte
* in a subsequent Data Record is obtained by adding the LBA to an
* offset calculated by adding the LOAD OFFSET field of the containing
* Data Record to the index of the byte in the Data Record (0, 1, 2,
* ... n). This offset addition is done modulo 4G (i.e., 32-bits),
* ignoring any carry, so that offset wrap-around loading (from
* OFFFFFFFFH to OOOOOOOOOH) results in wrapping around from the end
* to the beginning of the 4G linear address defined by the LBA. The
* linear address at which a particular byte is loaded is calculated
* as:
* (LBA + DRLO + DRI) MOD 4G
* where:
* DRLO is the LOAD OFFSET field of a Data Record.
* DRI is the data byte index within the Data Record.
* When an Extended Linear Address Record defines the value of LBA,
* it may appear anywhere within a 32-bit hexadecimal object file.
* This value remains in effect until another Extended Linear Address
* Record is encountered. The LBA defaults to zero until an Extended
* Linear Address Record is encountered.
//! \name the Extend Linear Address Record
internal class ExtendLinearAddressRecord : Record
private UInt16 m_UpperLinearBaseAddress = 0;
private Byte[] m_Data = null;
public ExtendLinearAddressRecord(Byte[] tData)
if (null == tData)
return;
else if (2 != tData.Length)
return ;
m_Data = tData;
try
Byte[] tTemp = new Byte[2];
tTemp[0] = tData[1];
tTemp[1] = tData[0];
m_UpperLinearBaseAddress = BitConverter.ToUInt16(tTemp, 0);
Err.ToString();
return;
m_bAvailable = true;
//! \brief record data length should always be 2
public override Int32 RecordLength
get
if (!m_bAvailable)
return 0;
return 2;
get { return Type.EXTEND_LINEAR_ADDRESS_RECORD; }
//! \brief get data
public override Byte[] Data
get
if (!m_bAvailable)
return null;
return m_Data;
//! \brief get the Upper Linear Base Address
public UInt32 UpperLinearBaseAddress
get
if (!m_bAvailable)
return 0;
return ((UInt32)m_UpperLinearBaseAddress) << 16;
//! \name the Start Segment Address Record
internal class StartSegmentAddressRecord : Record
private UInt32 m_StartSegmentAddress = 0;
public StartSegmentAddressRecord(Byte[] tData)
if (null == tData)
return;
else if (4 != tData.Length)
return;
m_Data = tData;
try
Byte[] tTemp = new Byte[4];
tTemp[0] = tData[3];
tTemp[1] = tData[2];
tTemp[2] = tData[1];
tTemp[3] = tData[0];
m_StartSegmentAddress = BitConverter.ToUInt32(tTemp, 0);
Err.ToString();
//! \brief always return 4
get
if (!m_bAvailable)
return 0;
return 4;
get { return Type.START_SEGMENT_ADDRESS_RECORD; }
//! \brief get data
get
if (!m_bAvailable)
return null;
return m_Data;
//! \brief get start segment address
public UInt32 StartSegmentAddress
get
if (!m_bAvailable)
return 0;
return m_StartSegmentAddress & 0x000FFFFF;
public UInt16 CS
get
if (!m_bAvailable)
return 0;
return (UInt16)(m_StartSegmentAddress & 0x0000FFFF);
public UInt16 IP
get
if (!m_bAvailable)
return 0;
return (UInt16)((m_StartSegmentAddress >> 16) & 0x000F);
/*! \note The Data Record provides a set of hexadecimal digits that represent
* the ASCII code for data bytes that make up a portion of a memory image.
* The method for calculating the absolute address (linear in the 8-bit
* and 32-bit case and segmented in the 16-bit case) for each byte of data
* is described in the discussions of the Extended Linear Address Record
* and the Extended Segment Address Record.
//! \name the Data Record
internal class DataRecord : Record
private UInt16 m_LoadOffset = 0;
//! \brief constructor for the Data Record
public DataRecord(UInt16 tLoadOffset, Byte[] tData)
if (null == tData)
return;
else if (tData.Length > 255)
return;
m_Data = tData;
m_LoadOffset = tLoadOffset;
//! \brief get record data length
get
if (null == m_Data)
return 0;
return m_Data.Length;
//! \brief get load offset
public override UInt16 LoadOffset
get
if (!m_bAvailable)
return 0;
return m_LoadOffset;
get { return Type.DATA_RECORD; }
get
if (!m_bAvailable)
return null;
return m_Data;
/*! \note The 16-bit Extended Segment Address Record is used to specify bits
* 4-19 of the Segment Base Address (SBA), where bits 0-3 of the SBA
* are zero. Bits 4-19 of the SBA are referred to as the Upper Segment
* Base Address (USBA). The absolute memory address of a content byte
* in a subsequent Data Record is obtained by adding the SBA to an
* ... n). This offset addition is done modulo 64K (i.e., 16-bits),
* ignoring any carry, so that offset wrap-around loading (from OFFFFH
* to OOOOOH) results in wrapping around from the end to the beginning
* of the 64K segment defined by the SBA. The address at which a
* particular byte is loaded is calculated as:
* SBA + ([DRLO + DRI] MOD 64K)
* where:
* When an Extended Segment Address Record defines the value of SBA,
* it may appear anywhere within a 16-bit hexadecimal object file. This
* value remains in effect until another Extended Segment Address Record
* is encountered. The SBA defaults to zero until an Extended Segment
* Address Record is encountered.
//! \name the Extend Segment Address Record
internal class ExtendSegmentAddressRecord : Record
private UInt16 m_ExtendSegmentUpperBaseAddress = 0;
public ExtendSegmentAddressRecord(Byte[] tData)
if (null == tData)
return;
return;
m_Data = tData;
try
m_ExtendSegmentUpperBaseAddress = BitConverter.ToUInt16(tTemp, 0);
Err.ToString();
return;
//! \brief always return 2
get
if (!m_bAvailable)
return 0;
return 2;
get { return Type.EXTEND_SEGMENT_ADDRESS_RECORD; }
//! \brief get data
get
if (!m_bAvailable)
return null;
return m_Data;
//! \brief get extend segment base address
public UInt32 ExtendSegmentBaseAddress
get
if (!m_bAvailable)
return 0;
return ((UInt32)m_ExtendSegmentUpperBaseAddress) << 4;
/*! \note The Start Linear Address Record is used to specify the execution start
* address for the object file. The value given is the 32-bit linear address
* for the EIP register. Note that this record only specifies the code
* address within the 32-bit linear address space of the 80386. If the code
* is to start execution in the real mode of the 80386, then the Start
* Segment Address Record should be used instead, since that record specifies
* both the CS and IP register contents necessary for real mode.
//! \name the Start Linear Address Record
internal class StartLinearAddressRecord : Record
private UInt32 m_StartLinearAddress = 0;
public StartLinearAddressRecord(Byte[] tData)
if (null == tData)
return;
return;
m_Data = tData;
try
m_StartLinearAddress = BitConverter.ToUInt32(tTemp, 0);
Err.ToString();
return ;
get
if (!m_bAvailable)
return 0;
return 4;
get { return Type.START_LINEAR_ADDRESS_RECORD; }
//! \brief get data
get
if (!m_bAvailable)
return null;
return m_Data;
//! \brief get start linear address (EIP)
public UInt32 StartLinearAddress
get
if (!m_bAvailable)
return 0;
return m_StartLinearAddress;
